Clutch Issue: play in clutch?
Old 07-10-2005, 07:25 PM
scrubachu's Avatar
Default Clutch Issue: play in clutch?
im having a problem with the clutch. out of nowhere, the clutch started engaging at a different height. today when i started it, it wouldnt go into any gear. before today, it shifted perfectly fine, and i had no prblems. i adjusted the pushrod underneath, making is shorter, and it went into gear fine. problem is, now ther eis some play in the pedal. re bled it, and then put in a new slave cylinder, and bled it again. while i was under the pedal, i checked the MC for any fluid, and nothing. i figure its still good since i put it in about 3k miles ago, and it was an oem honda one.
there is still a bit of play in the clutch, but it shifts and drives fine now. any ideas on what it could be?
Old 07-11-2005, 08:49 AM
scrubachu's Avatar
Default Re: Clutch Issue: play in clutch? (scrubachu)
bumo
keiserbikes
Transmission & Drivetrain
11-19-2012 07:26 AM
evade_07
12-13-2008 10:15 PM
ac_attak
06-07-2006 11:12 AM
hatchsi0485
11-21-2005 06:13 AM
jdmteg95
12-17-2002 03:52 AM
Quick Reply: Clutch Issue: play in clutch?
