Difference between SH and base model aside from atts?
Old Jul 14, 2005 | 09:55 AM
eg1vin's Avatar
Default Difference between SH and base model aside from atts?
Ok, when looking at parts for a bb6 ie. exhaust, two different versions of the part comes up, one for the sh and the other, non-sh. I know that the Sh has the atts system, but isn't that all in the tranny? what other factor requires the SH to use different parts?
Old Jul 14, 2005 | 10:08 AM
JeremyLude's Avatar
Default Re: Difference between SH and base model aside from atts? (eg1vin)
The exhausts for the SH are shorter then the Base. If you find an SH you want, you'll need an adaptor for the Base to fit.
Other then the ATTS there are a few subtle differences. Body color stock skirts, no rear deck brake light, lights in the inside of the doors..
Old Jul 14, 2005 | 10:12 AM
eg1vin's Avatar
what makes the exhaust shorter? shorter down pipe? shorter cat? is that the only difference as far as the engine goes? thanks..
Old Jul 14, 2005 | 12:17 PM
BB6racer's Avatar
the motor of an SH sits further away from the firewall to make room for the ATTS unit. to make up for the extra distance between the two, the headers and exhausts on a SH are longer. the collectors pipe size, and mufflers are all the same i think though. also, the suspension arms are all different from a base model and a SH, whick might have an affect of the exhaust pipe bends. the SH have a lower/sportier spring and shock setup than the base. but aftermarket suspension can be used to correct the height differences.
ludes2fast4u
Sep 14, 2008 11:15 AM
twiztid00002
Feb 1, 2008 06:08 PM
Vbp6us
Apr 25, 2005 09:46 AM
H22A EG6
Nov 6, 2003 09:22 PM
