Injector size
Old Jul 14, 2005 | 11:51 PM
Lude S's Avatar
Default Injector size
I have a 99lude and did the obd2 to obd1 conversion using P13 ecu. I have an idle issue becuz the obd2 290cc injectors are smaller than the obd1 345cc injectors.
If i get a VAFC and tuned down the fuel percentage cuz the H22a is running rich on the P13 ecu anyways, will my idle issues go away? Or will I have to get new injectors?
If i get injectors, will the 390cc RC injectors be too big for the H22a running on a stock P13 ecu??
Old Jul 15, 2005 | 08:05 AM
Lude S's Avatar
Default Re: Injector size (Lude S)
TTT
Old Jul 15, 2005 | 01:07 PM
The Weather Man's Avatar
Yes, your bad idle will go away if you get a VAFC - note: i'm not telling you to buy a VAFC...because i don't know your mods or anything about your vehicle....
...but it will definately do the trick.
Old Jul 15, 2005 | 01:18 PM
jmcmil6's Avatar
Default Re: (NaptownKing)
u could use the aft to add fuel to the engine, cuz the p13 wants to run more gas thinking u have 345cc's--- U should be able to idle 390's easy i have friends doing so on 440's w/ b20's --
I was able to get mine to idle w/ 550's about 60psi of fuel press w/ an afc
Old Jul 15, 2005 | 04:15 PM
Lude S's Avatar
Default Re: (jmcmil6)
I might even get a P28 and then run Hondata!
Old Jul 15, 2005 | 04:22 PM
v4lu3s's Avatar
RTFM
teh 290s flow the same as 345s.
the p13 is mapped for 345cc injectors at 36-40 psi
the p5 whatever is mapped for 290cc injectors at 47-50 psi.
if you do the math you see htey both end up flowing at around 320cc....
Old Jul 15, 2005 | 05:19 PM
Lude S's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">teh 290s flow the same as 345s.
if you do the math you see htey both end up flowing at around 320cc....</TD></TR></TABLE>
then how come a lot of ppl is getting this idle problem after doing the obd2 to obd1 P13 conversion?
Old Jul 16, 2005 | 03:25 PM
v4lu3s's Avatar
RTFM
it may not have anything to do with the injectors. im jsut stating that the acutal flow of the injectors ends up the same since 345cc and 290cc rating are both at 43 psi, and no h22a in a prelude operates at that pressure stock.
Old Jul 16, 2005 | 03:29 PM
^^^^ Makes A LOT of sense....learn something everyday eh....
Old Jul 16, 2005 | 03:33 PM
Lude S's Avatar
I am now starting to wonder what the problem rilly is!
egturbo
Jul 14, 2003 12:21 AM
95integrags-r
Jun 12, 2003 10:37 PM
sushibug
May 5, 2002 11:09 PM
blazin
Feb 12, 2002 10:40 AM
SpeedMonkeyRacing
Oct 4, 2001 07:28 AM
