distributor timing help
Old Sep 21, 2005 | 11:33 AM
chitownrida's Avatar
Default distributor timing help
ok.. i've been having alot of heistation right after i start the car... so i decided to check my timing.. rt now when i use the timing light on the flywheel it looks like this. (car is fully warm 750 rpm and service connector is jumped)
15 }
bracket is the mark on the block...
is this the correct timing?? should i be using stock specs for a boosted car??
thanks
Old Sep 23, 2005 | 08:13 PM
up for the techies
Old Sep 24, 2005 | 12:58 PM
LudeyKrus's Avatar
Sounds right to me.
What are you using for tuning, though?
Old Sep 24, 2005 | 01:08 PM
Hawkze_2.3's Avatar
Default Re: distributor timing help (chitownrida)
Well, you should get the timing tuned for your engine. You could gain/loose power at different rpm ranges depending on your setup and timing.
Are your timing marks ok for TDC on the flywheel and cam gears??
Old Sep 24, 2005 | 08:14 PM
acutally i havent checked the cam gears.
saving for aem ems
at this point the car is strictly bolt on drag kit
good lookin out
Old Sep 24, 2005 | 08:46 PM
l2yanE's Avatar
dude what kinda boost r u pushin?
aznfreakyguy
May 31, 2012 10:36 PM
Jsarv
Engine Management and Tuning
Apr 1, 2012 01:48 PM
bopbop93030
Feb 24, 2009 02:57 PM
johnwohl
Apr 1, 2008 07:29 PM
Hemi_powered
Feb 4, 2006 12:46 PM
