wiring issues
Old Sep 22, 2005 | 09:25 PM
iwubmybb4's Avatar
Default wiring issues
well.. i had this electrical problem.. when my car is sitting with all the accessories off it idles at 750.. but when i turn on my headlights or my heater the idle drops to 5##.. i had my alternator looked at and it is puttin out 85 amps or something like that.. anyways.. on the other side of the harness the one that connects to the battery terminal it is only gettin 30 amps... i was wondering if it would work if i took a wire (8 gauge) and connected it from the alternator to the battery with a 100amp fuse.. would this solve my problem...?! Somone plz help... thank you
Old Sep 22, 2005 | 11:27 PM
K-Spec's Avatar
Default Re: wiring issues (iwubmybb4)
it is normal for the rpm to fall a little when you turn on all your accessories because more power is being drawn to the battery. Did you use a volt-meter to measure the battery when it was idling? It should stay between 12v-14v.
Old Sep 22, 2005 | 11:35 PM
iwubmybb4's Avatar
Default Re: wiring issues (khalal538)
i know itz normal for the rpm to fall.. but 200 rpms is a lot.. keep in mind that it doesn't come back up... and yes i've checked it with a meter.
Old Sep 22, 2005 | 11:36 PM
iwubmybb4's Avatar
oops.. i forgot to mention if it matters.. it's a jdm h22 just recently swapped in.
Old Sep 23, 2005 | 12:01 AM
lude_behavior's Avatar
its rather normal. When you turn on any accessory whatsoever, your RMPs and your voltage is going to grop. I work with car stereo systems, "aka pimping people's rides" all day long.
Old Sep 23, 2005 | 12:03 AM
Default Re: wiring issues (lude_behavior)
My car is the same way. I turn my car on and my amps draw enough power to supply a small country with enough power and I have NO SUBS.
Old Sep 23, 2005 | 12:24 AM
iwubmybb4's Avatar
this still makes no sense to me.. are you telling me your idle drops to the point where the motor starts shaking?! almost like the car is going to die... oh well.. i'm gonna go to an alternator shop tomorrow and check it.
ksr111851
Jul 20, 2017 08:09 AM
Tommy_Gunns
Sep 11, 2009 12:10 AM
jlh22179tx
Jan 20, 2007 09:15 AM
sky88
Jul 17, 2004 11:30 AM
nevin
Aug 11, 2003 09:59 AM
