no vtec??
Old Sep 22, 2005 | 02:49 AM
chelsea's Avatar
Default no vtec??
got a 94 2.2 vtec with no vtec? engine light comes on over 5k revs? runs fine though apart from this. 170k on engine. whats it all about??
Old Sep 22, 2005 | 03:05 AM
Lewdin' Incognito's Avatar
Default Re: no v-tech?? (chelsea)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chelsea &raquo;</TD></TR><TR><TD CLASS="quote">got a 94 2.2 v-tech with no v-tech? engine light comes on over 5k revs? runs fine though apart from this. 170k on engine. whats it all about?? </TD></TR></TABLE>
Exactly, I'm not sure but it sounds like you're getting an error when vtec is supposed to engaged. I would start checking the connections on the vtec solenoid, the solenoid itself, and check your oil?
EDIT: Does the error code stay on after you go back down below 5000rpms? Have you done any mods or other fixes recently?
Modified by Lewdin' Incognito at 4:51 AM 9/22/2005
Old Sep 22, 2005 | 03:43 AM
Demonlude's Avatar
Default Re: no v-tech?? (Lewdin' Incognito)
I would actually start by checking the error code first. I believe a CEL will cut the vtec regardless of whether it's actually a vtec problem.
Have a look round on the forum (probably in FAQ) about how to check the error code, then tell us what it is. Technically speaking, Honda tells you not to drive the car with a CEL on, although if you just drive it gently, you should be fine.
Old Sep 23, 2005 | 01:53 PM
chelsea's Avatar
reset light next day,aint driving it hard now,booked in docs ,let u know outcome
thangbui
Oct 23, 2005 08:05 AM
dkboyny11
Jun 2, 2005 03:45 PM
Metrocity2
Apr 27, 2005 02:03 AM
GTA
11
Aug 25, 2004 11:03 PM
just_a_sohc
Dec 27, 2001 08:52 AM
