electrical problem?
Old Sep 17, 2005 | 03:27 PM
gvcustoms's Avatar
Default electrical problem?
problem here on my 92 prelude when i was driving the other day out of nowhere the windsheild wipers slooowly started comin up, also noticed the left blinker light came on solid as this was happening? havent really had the chance to look at it yet, this happend on the way to the paint shop.
Old Sep 17, 2005 | 04:38 PM
loser4ws's Avatar
Default Re: electrical problem? (stuntman)
check your wiper and turn signal switch.
Old Sep 17, 2005 | 07:51 PM
gvcustoms's Avatar
Default Re: electrical problem? (loser4ws)
no no Im pretty sure I would of realized of the switches were on but they werent, and it kept on doin it, control switch wiring maybe? anybody else got an idea.
Old Sep 17, 2005 | 09:03 PM
AnthonyG2003
Guest
Posts: n/a
Completely off of his topic, but I was wondering why my "Brake Lamp" light stays on...I have checked all my bulbs and my brakes are NEW...I have no idea what to do! Any suggestions?
Old Sep 18, 2005 | 02:03 PM
gvcustoms's Avatar
Default Re: electrical problem? (AnthonyG2003)
for some reason youre ecu might think theres a brake lamp out, try unplugging youre battery for 5 minutes to reset the ecu.
Old Sep 18, 2005 | 08:50 PM
AnthonyG2003
Guest
Posts: n/a
If I unplug the battery for 5 minutes then hook it back up...I wont have to do anything other than plug it back up will I?
Old Sep 19, 2005 | 01:00 AM
GT_Alpha's Avatar
Still off topic but my car does the same thing but I noticed that it only happens if I press the brake peddle when I start the car, otherwise the light goes off on start up like normal, but if i start with the brake pressed it will stay on the entire time the car is running.
If anyone has any other suggestions it would be great.
Old Sep 19, 2005 | 05:23 AM
loser4ws's Avatar
Default Re: (GT_Alpha)
HAVE YOU CHECKED THE SWITCH ON YOUR PEDAL THERE SHOULD BE A LITTLE CLIP THAT CLIPS IN A HOLE AT THE TOP OF THE PEDAL THAT HOLDS THE SWITCH CLOSED WHEN THE PEDAL IS NOT PRESSED. SO THE LIGHTS WILL STAY OFF UNTILL YOU PRESS THE PEDAL.
Old Sep 29, 2005 | 09:47 AM
gabspeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AnthonyG2003 &raquo;</TD></TR><TR><TD CLASS="quote">Completely off of his topic, but I was wondering why my "Brake Lamp" light stays on...I have checked all my bulbs and my brakes are NEW...I have no idea what to do! Any suggestions?</TD></TR></TABLE>
your brake fluid is low fill it up and the light should go off
Old Sep 29, 2005 | 09:51 AM
AnthonyG2003
Guest
Posts: n/a
Default Re: electrical problem? (gabspeed)
brake fluid is full...thats the 2nd placed i looked.
s13_240sx_92's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stuntman &raquo;</TD></TR><TR><TD CLASS="quote">for some reason youre ecu might think theres a brake lamp out, try unplugging youre battery for 5 minutes to reset the ecu.</TD></TR></TABLE>
Its the blind leading the blind...
Check your master cylinder fluid. Then check all the wiring for the brake lights. There are sensors in the tail lights that will put the brake light up.
AdamAccord
Nov 7, 2017 05:19 PM
SOblOwN
Sep 5, 2013 07:08 PM
PillPusher
Feb 11, 2011 08:37 AM
phanatic
Jun 14, 2006 03:06 AM
Groove_D
Jun 22, 2004 02:18 PM
