new engine install
Old Sep 19, 2005 | 09:42 AM
andre809_lude's Avatar
Default new engine install
hey...ive never done an engine instal just wanted to know ...Do i have to take the tranny out in order to remove an old engine and instal a new one, I really dont want to take the drive shafts out.....anything would hlp
Old Sep 19, 2005 | 09:46 AM
flyrod's Avatar
Default Re: new engine install (andre809_lude)
You don't have to, but I think it would be easier to just pull everything as one piece. At a minimum I remove the crank pulley to get a few cm more clearance. Good luck.
Old Sep 19, 2005 | 10:01 AM
Default Re: new engine install (flyrod)
cool thanks bro.... ill see what happens
Old Sep 19, 2005 | 11:38 AM
syntax.'s Avatar
If you are scared of pulling the driveshafts then you will be terrified once you get elbows deep in trying to pull that engine.
The axles are an easy thing to remove and pulling the engine and tranny as a unit makes the whole ordeal much much easier
Old Sep 19, 2005 | 11:43 AM
2lude4u's Avatar
Default Re: new engine install (syntax420)
It's a lot easier to bolt and unbolt the tranny when it's removed w/ the engine. Messing with the CV axles may seem cumbersome, as it will be the first time, but is something you may as well learn to do effectively now especially if you plan on doing future swaps.
Old Sep 19, 2005 | 12:23 PM
PrecisionH23a's Avatar
You will kill yourself if you try removing just the engine while leaving the tranny in place.
Yank it out as a whole and place it back in as a whole. Get an adjustable linkage for the hoist so you can lower one side of the engine while raising the other.
Old Sep 19, 2005 | 12:31 PM
eff sea's Avatar
Default Re: new engine install (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">You will kill yourself if you try removing just the engine while leaving the tranny in place.
Yank it out as a whole and place it back in as a whole. Get an adjustable linkage for the hoist so you can lower one side of the engine while raising the other.</TD></TR></TABLE>
Where would you get something like that? I'm going to be using a hoist soon, and that seems like it would be useful.
qazaq
Jan 23, 2009 05:01 PM
Mugensports187
Nov 9, 2007 06:35 PM
xrunner86x
Mar 7, 2007 05:19 AM
alupso
24
Jan 24, 2006 12:08 PM
non-VTEC
Apr 9, 2002 11:31 AM
