5th grinds
Old Sep 17, 2005 | 07:58 PM
URtaxes's Avatar
Default 5th grinds
My lude is a 99 with 64k and when i shift into 5th fast or faster than a normal person. the gears grind, my guess is syncros. yours?
Old Sep 17, 2005 | 08:10 PM
RemerLex11's Avatar
Default Re: 5th grinds (URtaxes)
happens to me too its probably your synchros. i changed my tranny fluid and it helped a bit but i just double clutch into 5th now and it doesnt grind.
Old Sep 18, 2005 | 02:38 AM
rival12's Avatar
everyone with an H22 seems to have 5th gear grinds....all my friends anyways....i have none good old Jap Spec
Old Sep 18, 2005 | 06:17 AM
machine4321's Avatar
theres TSB out the *** fo rthis problem , its very common in the h and f trannies , its a missalignment in the 5th gear shift fork , contact honda , some will do a goodwill repair under warrenty
Old Sep 18, 2005 | 07:41 AM
v4lu3s's Avatar
RTFM
Default Re: (machine4321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by machine4321 &raquo;</TD></TR><TR><TD CLASS="quote">theres TSB out the *** fo rthis problem , its very common in the h and f trannies , its a missalignment in the 5th gear shift fork , contact honda , some will do a goodwill repair under warrenty </TD></TR></TABLE>
Yeah i was gonna say the same thing.
its not syncros....its somethign hond has known about for years and has posted fixes to to all their dealers as well as honda repair shops that participate in honda programs.
Old Sep 18, 2005 | 11:12 AM
zexifiedlude's Avatar
so does honda have a recall or anyhting to fix it? cause i defently dont have a warenty
Old Sep 18, 2005 | 12:31 PM
v4lu3s's Avatar
RTFM
it is a Technical Service Bulletin. Not a recall, so it does cost to have the work done.
Old Sep 18, 2005 | 01:39 PM
prelude1897's Avatar
Default Re: (v4lu3s)
Most 5th Gen. Preludes have this problem....I have this problem with mine, so I usually just double shift when going into 5th gear, and it won't happen
Old Sep 18, 2005 | 03:22 PM
in the TSB i saw it siad it was eligible for a goodwill repair , but its not a garenteed warrenty issue
Old Sep 20, 2005 | 04:38 PM
whats a goodwill repair
Old Sep 20, 2005 | 07:05 PM
v4lu3s's Avatar
RTFM
the service manager may agree to do the repair at no charge. it usually helps when asking for a goodwill repair to be a regular custoemr of the service department and have purchased the car at that dealer though.
Old Dec 18, 2005 | 11:20 AM
The Weather Man's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by machine4321 &raquo;</TD></TR><TR><TD CLASS="quote">in the TSB i saw it siad it was eligible for a goodwill repair , but its not a garenteed warrenty issue </TD></TR></TABLE>
I posted the TSB a while back. Do a search for it - i'll try to find it myself.
Old Dec 18, 2005 | 11:22 AM
HAHA! Found it.
https://honda-tech.com/zerothread?id=1376753
Glad i could hlep.
Old Dec 18, 2005 | 01:40 PM
kornerk12's Avatar
Default Re: (TheKINGPin)
So basicly its up to them then if they want to do it for free ? Or do you still have to pay labor or somethin? Because i dont wana pay for something that was not manufactured correctly.
Old Dec 18, 2005 | 03:35 PM
CivicSiDriver02's Avatar
Default Re: (kornerk12)
If you haven't already, try bleeding the clutch system. My lude did the same thing. After i bled it the grind went away. Also you may want to try some synchromesh. This is a controversial topic on HT but ive had it im my tranny for about 15k miles and haven't had any grinding problems.
Rinsta
Aug 6, 2008 11:06 PM
Mmmeecho
10
Jul 28, 2008 09:06 PM
HeatherJ
Aug 23, 2006 01:23 PM
smokedyou19
May 25, 2006 09:53 AM
AgentUT
Apr 18, 2004 06:39 PM
