H22A1 hp question
H22A1 hp question
Aren't JDM H22's just called H22A and USDM are like H22A1, H22A3 etc...Well I have a H22A1 and I was told that it was a JDM engine. Doesn't it being a H22A1 make it USDM? And its from a '95 so it should have a 190 hp right? i just want to have everything straight.
Re: H22A1 hp question (buffalo wings)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by buffalo wings »</TD></TR><TR><TD CLASS="quote">so ur h22a1 is from a 93-95 usdm lude and is rated from the factory at 190hp w/ 10:1 compression</TD></TR></TABLE>
H22A1 is 93-96
H22A4 is 97-01 (Base and Type SH)
H22A1 and H22A4's are ALL 190HP.
H22A1 is 93-96
Re: H22A1 hp question (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">isnt a 96 OBDII tho?</TD></TR></TABLE>
yeah, i was assuming he only wanted obd I engine info...
ok now I have another question.
On my other prelude obd2 the redline is mid 7k
On my '95 it redlines a 6537 rpm. It does have a JDM p-13 ecu but what should it be stock? I thought it was like 7.3k or something. I think the JDM ecu might be screwing me over since I THINK Im losing 1 grand of rpms. And the ecu is not chipped or anything. but I tuned the air/fuel with my vafc.
Re: H22A1 hp question (domestic_rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by domestic_rice »</TD></TR><TR><TD CLASS="quote">ok now I have another question.
On my '95 it redlines a 6537 rpm. It does have a JDM p-13 ecu but what should it be stock? I thought it was like 7.3k or something. I think the JDM ecu might be screwing me over since I THINK Im losing 1 grand of rpms. And the ecu is not chipped or anything. but I tuned the air/fuel with my vafc.</TD></TR></TABLE>
H22s redline at 7200. Try either disconnecting the AFC or making it not change anything and see if that helps. Also, check your CEL.
yes, but it's still an H22A1
Re: H22A1 hp question (SKDRCR)
ok well Im not getting any codes at all. But I don't have an oil pressure gauge. And It does feel like fuel cut off now that I think of it. Like in my stang before I got the bigger fuel pump and injectors. But I did just have a balance shaft seal that went out. It wasn't leaking at all before it just popped out one day. I just popped it back in and don't drive it much.
