JUN vs Skunk2
Old Oct 10, 2005 | 09:57 PM
st3alth's Avatar
Default JUN vs Skunk2
What would u choose?
skunk2 stage 2 cams.. cam gears... valvetrain upgrade
vs
jun cams(only 1 type for h22a)... cam gears.. valvetrain upgrade
specs of the cams to compare can be found here
http://www.skunk2.com/s2site/e...p.htm
http://www.junauto.co.jp/produ...ml?en
well the duration on the jun is longer for the vtec lobe..
s2 doesn't state their lift/duration for the primary and secondary lobes so i'm guessing it's just left stock?
Old Oct 10, 2005 | 10:29 PM
The Birdman's Avatar
Default Re: JUN vs Skunk2 ([ S7H ])
JUN all day long!
Old Oct 10, 2005 | 10:31 PM
mgags7's Avatar
and all night....
gross...
Old Oct 10, 2005 | 10:38 PM
Default Re: (mgags7)
someone is missing their woman...
Old Oct 10, 2005 | 10:55 PM
JTCdudeman's Avatar
Master H Technician
Default Re: (jd3jdm)
JUN JUN JUN....
Old Oct 10, 2005 | 11:09 PM
st3alth's Avatar
anyone know how high a JUN setup like this would let u rev too?
also... how streetable is something like this..
i realise idle would be compromised(to some extent) but would it still be OK as a daily?
Old Oct 10, 2005 | 11:36 PM
mgags7's Avatar
it would be fine for a daily driver...
as far as revving, those cams will make power as high as you can rev....they are huge...seriously, like 9k and up will be fine....thats not to say that a stock block could do that though....
Old Oct 10, 2005 | 11:42 PM
BlAxNaIl's Avatar
Default Re: JUN vs Skunk2 (jspech22)
i almost got "JUN" tatooed on my head!! well not really my head, i mean valve cover
Old Oct 11, 2005 | 01:03 AM
st3alth's Avatar
what kind of extra stuff would i be looking @ to keep it revving nicely to 9krpm+.. just thru the whole power band basically...
the jun stuff isnt enuff? + headers + exhaust + tuning?
Modified by jspech22 at 5:09 AM 10/11/2005
Old Oct 11, 2005 | 05:18 AM
iakona's Avatar
JUN cams, some Ti retainers, and dual springs that can take that lift. not all can, so beware...
oh, and JUUUUUUUUUUUN all day every day baby!
Old Oct 11, 2005 | 06:00 AM
st3alth's Avatar
well im quiet sure JUN only make 1 type of valve spring and retainers for H22A?
Old Oct 11, 2005 | 06:18 AM
iakona's Avatar
yes JUN does, but there are many other manufacturers out there with springs that can handle big lift (without the JUN pricetag). Supertech, Ferrea, etc.
Old Oct 11, 2005 | 06:54 AM
The Weather Man's Avatar
KMS claims their dual springs have been tested to perform reliably to 10,000 rpm - they only cost $174.95 - for the H series
Old Oct 11, 2005 | 06:55 AM
iakona's Avatar
that may be true, and that is very cool, but at what lift?
Old Oct 11, 2005 | 07:01 AM
High-strength chrome silicon springs. 75 psi seat pressure for reliable performance up to 10,000 rpm.
KMS Race Springs are perfect for high rev applications.
For strength, weight, fit, and finish KMS Race Springs can go head-to-head with any leading brand.
KMS provides the highest quality springs better price.
http://honda-performance.com/info-lv2.asp?id=419
Old Oct 11, 2005 | 07:02 AM
With their entire valvetrain ( springs, retainers, seats.....) They're saying 11,000rpm can be acheived reliably..........
http://honda-performance.com/valve-train.asp
And it only cost $599.00 W/ a block guard
Old Oct 11, 2005 | 07:10 AM
st3alth's Avatar
hmm that valvetrain package looks impressive.. can anyone else say these are good too?
so the JUN valvetrain set wouldnt be able to sustain such power? or u saying there are cheaper alternatives in maintaing such power/lift from the JUN cams?
Old Oct 11, 2005 | 07:15 AM
I'm pretty sure JUN can handle it - but the price is the biggy. I know for a fact that KMS is a reputable company.
I've been looking into their stuff for a year.
Go to Honda-performance.com
They've been around for a while.
Old Oct 11, 2005 | 07:17 AM
iakona's Avatar
i agree, it looks great, but my point is the measured Max Lift (or spring compression).
JUN:???
Manley:.790"
Ferrea:13.5mm
Supertech:13.5mm
KMS: ???
and block guards are not necessarily teh best invention. IMHO.
Old Oct 11, 2005 | 07:20 AM
st3alth's Avatar
yeah im looking into a JUN package that includes..
Cams... CGears... Springs... Retainers... (can i rev beyond 9k.. say 10-11?)
then perhaps...
JUN Clutch + lightened flywheel...
Old Oct 11, 2005 | 07:22 AM
mgags7's Avatar
youre gonna need some light *** bottom end components to spin out 10-11k rpms....otherwise you will be ruining bearings like its your job...
Old Oct 11, 2005 | 07:24 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">youre gonna need some light *** bottom end components to spin out 10-11k rpms....otherwise you will be ruining bearings like its your job...</TD></TR></TABLE>
I think he's just talking about reliability - atleast i hope.
Old Oct 11, 2005 | 07:26 AM
atropos's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">yeah im looking into a JUN package that includes..
Cams... CGears... Springs... Retainers... </TD></TR></TABLE>
ditto. Would the car run ok w/ this setup and the stock ecu? (I realize a hondata setup or equiv. would be best, but there would be times when the stock ecu would be needed)
Old Oct 11, 2005 | 07:28 AM
st3alth's Avatar
components such as? (if i wanted to venture that far)
Old Oct 11, 2005 | 07:38 AM
iakona's Avatar
full blueprint + lightened crank, knife edged, rotationally balanced, light (super light, like Ti light) rods, small skirt lightweight pistons, etc.
