running p14 on an H22
you'll be fine, just remember to keep the revs down cuz its gonna be running the fuel as if it were a h23, and you rev limiter will be lower.....but you shouldnt be going anywhere near it
Yeah - i'm driving on my p14 - i've been doing it for a while now....my hondata s300 should be here monday - i missed it yesterday. ......i haven't had any problems at all. Its very responsive
ok i just plugged in the P14 and finally put the regular injectors in the car(345cc) because i had the H23 ones in there temporarily. now the car is running very rich at idle and seems leaned out at steady 3000 rpm driving. was misfiring, stalling and everything. dont know whats wrong, maybe the ecu just needs to relearn itself? i dont know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mck26 »</TD></TR><TR><TD CLASS="quote">ok i just plugged in the P14 and finally put the regular injectors in the car(345cc) because i had the H23 ones in there temporarily. now the car is running very rich at idle and seems leaned out at steady 3000 rpm driving. was misfiring, stalling and everything. dont know whats wrong, maybe the ecu just needs to relearn itself? i dont know. </TD></TR></TABLE>
It's probably because the p14 ecu is designed to work with 240cc injectors, not 345cc injectors.
Stay out of VTEC, oh wait, you don't have VTEC
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shutta »</TD></TR><TR><TD CLASS="quote">i just got motor/tranny/ecu (not sure which one) but if it's a p13 i should use that instead of the stock one for the h23 prelude?</TD></TR></TABLE>
Yes, if you recieved the h22 motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">you'll be fine, just remember to keep the revs down cuz its gonna be running the fuel as if it were a h23, and you rev limiter will be lower.....but you shouldnt be going anywhere near it</TD></TR></TABLE>
ok thanks for info. now car is throwing CEL 43 which is for fuel delivery system. any ideas? i dont know. it threw that code before about 4 months ago then cleared itself, now its back. also i turned the distributor back which seemed to lean it a bit and let it run a bit smoother. plugs are real dark brown/black after about 15 miles of driving. still rich. i guess i just gotta deal with this until the P13 comes. by the way, do you know anyone selling a manual USDM P13. or JDM but US preferred.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mck26 »</TD></TR><TR><TD CLASS="quote"> do you know anyone selling a manual USDM P13. or JDM but US preferred.</TD></TR></TABLE>
There's a usdm one on ebay going for 10 bucks, better jump on that.
Type in the phrase "p13 ecu"
theres someone now selling a p13 ecu and a knock sensor - i just sold mine two days ago to the_head.......hmm..........
Thats weird though because my car runs with no CEL on the p14 ecu.........thats so weird.........when i put the p13, it runs like ****.
Probably my fuel system.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mck26 »</TD></TR><TR><TD CLASS="quote">now car is throwing CEL 43 which is for fuel delivery system. any ideas?</TD></TR></TABLE>
That's clear up when you plug in the p13.
Yes, you can (I had to do the same because of the same as you
But:
1. Don't try to pass emission test with P14.
2. If you use P14 for a long time, say bye bye to your o2 sensor and Cat.
3. Don't go over 6500 rpm.
).But:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wstef »</TD></TR><TR><TD CLASS="quote">Yes, you can (I had to do the same because of the same as you
But:
3. Don't go over 6500 rpm.</TD></TR></TABLE>
Yep .....your cat and o2 are history.......oh yeah.
).But:
