Problem with new shift knob.
Old Oct 12, 2005 | 08:15 PM
Drag'nGT's Avatar
Default Problem with new shift ****.
First off I wanna say that I would put this in the appearance forum if the site would let me. I guess I'm gonna be a trial user for...... well who knows.
Anyway, I ordered a new Sparco Fast-R shift **** and it came in today. So I was pretty stoked to get home and install it. I got home and saw how I'm supposed to install this **** and lets just say I'm pretty damn upset. The shifter lever is alot smaller in diameter than the shift **** is. You put this little cap on top of your shift lever and use these little pointed alan screws to secure the cap onto the lever. Then you take the shift **** and screw it on-top of the little cap.
Granted this is a Sparco **** and Sparco is supposed to be a wonderful company. But this **** just makes me uncomfortable. I've got the thing on there securely and it doesn't have any play. But my concern is that after using it for a few months I'm gonna be going through the gears and boom! It pops off while driving and strips my shift lever's factory threads.
Is this common with aftermarket *****? Does Razo or Skunk2 retrofit their *****?
Old Oct 12, 2005 | 08:47 PM
Eddiebx's Avatar
if you install it properly it wont come off, lots of aftermarket ***** are not vehicle specific, hence why they dont screw on to your tsock threads.
for example i think almost all of the momo ones attach with allen screws too.
Old Oct 12, 2005 | 10:56 PM
bad-monkey's Avatar
momo and sparco ***** are all this way, i ended up using rubber grommets that are the same OD as the diameter of the **** hole, and have an ID that is the same size as the shift lever. this makes the fit nice and snug, and i've never had an issue w/ the **** coming off (i've used a momo and a sparco.)
Old Oct 13, 2005 | 05:49 AM
Drag'nGT's Avatar
Default Re: (bad-monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey &raquo;</TD></TR><TR><TD CLASS="quote">momo and sparco ***** are all this way, i ended up using rubber grommets that are the same OD as the diameter of the **** hole, and have an ID that is the same size as the shift lever. this makes the fit nice and snug, and i've never had an issue w/ the **** coming off (i've used a momo and a sparco.) </TD></TR></TABLE>
Could you please take some pics of that?
Old Oct 13, 2005 | 06:59 AM
mgags7's Avatar
razo ***** are the same....if that thing slips off....those threads are not coming with it, something else will let loose....
Old Oct 13, 2005 | 07:51 AM
The_Sober's Avatar
Default Re: (mgags7)
you wanna feel better about it? no problem. Just go to a hardware store, find a nut the same size as the threads on the shifter, and permanently affix it to the inside of the shift ****--I'll leave that to your own devices. I don't want to take all the fun out of it...
this'll pretty much guarantee that **** ain't comin' off...
Old Oct 13, 2005 | 09:09 AM
Hawkze_2.3's Avatar
Default Re: Problem with new shift ****. (Drag'nGT)
Order this one and it just screws on nice and snug--https://honda-tech.com/zerothread?id=1309365
I'm very happy with mine, it's heavy and feels great.
Old Oct 13, 2005 | 10:38 AM
bad-monkey's Avatar
Default Re: (Drag'nGT)
i'll try, or at least draw you something in MS paint.
Old Oct 13, 2005 | 11:42 AM
rawNArsxS's Avatar
Default Re: Problem with new shift ****. (Hawkze_2.3)
is that shiftknob looks to be in a 5th gen...do they have the same threading as a 4th gen so itll fit right onto a 4th gen shifter also?
Old Oct 13, 2005 | 01:13 PM
Drag'nGT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey &raquo;</TD></TR><TR><TD CLASS="quote">i'll try, or at least draw you something in MS paint.</TD></TR></TABLE>
Thank you.
rawNAprelude, are you asking if my **** is for a 5th gen or are you refering to Hawkze_2.3's post with that picture? If so, then no, that's not a 5th gen lude.
Carkid95
Jan 21, 2014 07:28 PM
Revolver123
Honda Civic (2001 - 2005)
Jul 21, 2008 06:55 PM
tnewhallSi
Mar 31, 2006 11:44 PM
Ludester
Dec 30, 2002 04:06 PM
