Knock sensor to retared timing?
Old Oct 8, 2005 | 08:53 PM
DrivinVtec's Avatar
Default Knock sensor to retared timing?
I got this direct port nitrous system that im puting on sometime this month, and i need something to retarted timing. i was wondering is there a way to use the knock sensor? From my understanding when the KS kicks in it retared the tmiing about 2 degrees. is that right? his was just and idea i had running around in my head. Thanks
Old Oct 8, 2005 | 09:10 PM
The Phil's Avatar
Default Re: Knock sensor to retared timing? (DrivinVtec)
Doesn't KS input also disallow VTEC engagement?
Old Oct 9, 2005 | 05:26 AM
Under_Pressure's Avatar
Default Re: Knock sensor to retared timing? (The Phil)
no knock retards timing and adds fuel. it stops working at 5500rpm then goes to normal. vtec can engage with code 23.
Old Oct 9, 2005 | 10:21 AM
DrivinVtec's Avatar
Thanks for the info
AnAccordIsForever
Nov 13, 2007 08:31 AM
EFGeeSeR
Oct 31, 2003 11:49 AM
toooslow
Apr 24, 2003 04:24 PM
batboyvaj
Jul 29, 2002 03:33 PM
