CODE 43: fixing issues !!!!
Old Oct 12, 2005 | 04:27 PM
DarkBB4's Avatar
Default CODE 43: fixing issues !!!!
Hey i got a code 43, so idid my research and i wen tout and bought a brand new OEM o2 sensor.. what else could be the problem.. im runing mad rich
Old Oct 12, 2005 | 05:07 PM
Rudelude22's Avatar
hey i got the same thing, are you running a header and what brand o2 did you buy.
Old Oct 12, 2005 | 05:11 PM
homesauce's Avatar
Default Re: (Rudelude22)
the problem is probably that you are running mad rich then.
DarkBB4's Avatar
yes runing a header
i bought a "walker" o2 sensor
Old Oct 12, 2005 | 07:53 PM
DarkBB4's Avatar
Default Re: (DarkBB4)
Old Oct 13, 2005 | 03:31 AM
pentaq's Avatar
valves?
Old Oct 13, 2005 | 03:35 AM
syntax.'s Avatar
fuel injector stuck open?
Old Oct 13, 2005 | 04:14 AM
v4lu3s's Avatar
RTFM
when did you last adjust your valves?
Old Oct 13, 2005 | 04:17 AM
kulrevon's Avatar
Default Re: (v4lu3s)
did you replace the o2 sensor yet?
Old Oct 13, 2005 | 07:20 AM
mgags7's Avatar
i always stick with oem parts....i havent had a problem yet....its worth the extra money...
you sell the lude yet dark??
Old Oct 13, 2005 | 07:36 AM
LudeyKrus's Avatar
The 43 code is usually a bad O2 sensor. It can also be the FPR, fuel filter, or possibly injector or bad gas from what I've seen and read.
Old Oct 13, 2005 | 09:47 AM
pentaq's Avatar
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">i always stick with oem parts....i havent had a problem yet....its worth the extra money...
Walker is OK. I had an issue with 43 CEL and bought exactly the same sensor. Also replaced the fuel filter and adjusted valves. It helped.
Old Oct 13, 2005 | 12:11 PM
DarkBB4's Avatar
Default Re: (pentaq)
ya walker should be good
i gotta change the plugs.. the fuel filter was just hcanged ...
maybe ill see if he can do a valve adjustment too
Old Oct 13, 2005 | 05:47 PM
PrettyLude's Avatar
get an o2 sim to get rid of that light
Old Oct 14, 2005 | 12:45 AM
Layziejoe775's Avatar
Default Re: (PrettyLude)
where can you get an o2 sim....HONDA....autozone...pepboys?
Old Oct 14, 2005 | 04:02 AM
amckee's Avatar
Check for air leaks. #1 cause of mad rich engines. This overly rich condition is probably what fouled your O2 sensor. Was it really carboned up? When I read rich running threads, I always see people that ask if they changed their fuel filter. Please explain to me how a restriction in fuel delivery can make a engine run rich.
Old Oct 14, 2005 | 11:32 AM
DarkBB4's Avatar
Default Re: (amckee)
i replaced a fuel line (soft rubber line... cause it was leaking... and its not leaking anymore
maybe its kinked or smoetings wrongw ith it?
Old Oct 14, 2005 | 11:56 AM
amckee's Avatar
No, I was refering to vacuum leaks.
Old Oct 14, 2005 | 08:07 PM
deng.....i have fu**kin 3 codes i found out 21, 23, and 43...on my h22a....i want everything to be back....HELP
jimmy o.
Apr 27, 2008 05:26 PM
lance_ecl
Mar 6, 2008 08:27 PM
spencedogg
13
Oct 28, 2003 06:45 PM
MikelH
Aug 25, 2003 07:30 PM
