Radiator problem...
Old Dec 14, 2005 | 04:03 PM
FD3S's Avatar
Default Radiator problem...
Hey guys -
I think my radiator sprung a leak yesterday. When the car gets warmed up i can see a little bit of steam coming out from under the hood. I can't really locate the leak but it is coming from the bottom somewhere. I was wondering what my options are right now. Will I have to replace the whole thing? How much am I looking at approximately?
Thanks in advance!
Old Dec 14, 2005 | 04:05 PM
The_Sober's Avatar
Default Re: Radiator problem... (FD3S)
well....the best thing to do is either replace the radiator or find a REALLY good welder and fix the leak. Ultimately, though, another leak will probably spring in the radiator and you'll need a new one. That's if it's the radiator...
it's probably one of the hoses. check 'em all, and replace what you need...
Old Dec 14, 2005 | 04:34 PM
prelude1897's Avatar
Default Re: Radiator problem... (The_Sober)
Defenitly check your hoses first. If they look fine, then check around on your radiator
Old Dec 15, 2005 | 08:26 AM
jakeiscool's Avatar
Banned
Seeing that a new radiator is like 100 dollars it wouldnt be worth it to pay someone to weld it. I know it seems stupid but make sure the cap is on all the way.
Old Dec 15, 2005 | 08:37 AM
AndyD's Avatar
Default Re: Radiator problem... (JakeIsCool)
Yes, check the radiator hoses, the cap, and the radiator.
If the radiator has a leak, I would just replace it. Get an OEM replacement for less than $115 shipped to you. If the radiator has a hole in it, that means it is dead. The cooling system is not something you want to cheap out on.
vxtirent08
Mar 20, 2008 10:36 AM
Shoobie
Sep 29, 2005 08:44 PM
tkHBseries
Feb 19, 2005 06:48 PM
Audio28
Dec 29, 2002 04:44 PM
kingpen
Oct 31, 2002 12:19 PM
