CEL code 36?
Old Dec 12, 2005 | 01:29 PM
tuyettam's Avatar
Default CEL code 36?
My dad just bought a 96 prelude i think, has automatic h22a. gear selector works fine in every gear except for reverse. Also a plug on the tranny has the ORG/BLU WHT/BLU ripped out from the plug. Would anyone know if there is even a code 36 and also wat plug is that goin to? and would that plug be the reason why its not operating in reverse?
Old Dec 12, 2005 | 06:47 PM
roller3804's Avatar
Default Re: CEL code 36? (tuyettam)
It is not a 96 if it has h22a with auto tranny. It could be swapped but I doubt it.
There is no code 36. Find a helms manual online and find out what the plug is. superhonda has one in the prelude FAQ
good luck
Old Dec 12, 2005 | 07:15 PM
SteveoBA8's Avatar
Default Re: CEL code 36? (camrann)
Could be a jdm h22 with jdm auto trans swap, according to my Fsm there is no code 36, but there are codes 30,31 30 is A/T Fi signal A and 31 is signal B, Probable cause for these is problem in A/t control unit and/or ecu circuit. Your ripped out wires are causing these codes so redo the cel flash, maybe you mis-counted it.
As for the wires
ORG/BLU and the WHT/BLU wires are for the mainshaft speed sensor. Thats probably why it wont shift into reverse. If there is enough wire to resolder it do that and if not then go to a junk yard and get yourself a new plug off of an auto accord tranny or somethen. Good luck.
Old Dec 12, 2005 | 07:33 PM
roller3804's Avatar
Default Re: CEL code 36? (SteveoBA8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SteveoBA8 &raquo;</TD></TR><TR><TD CLASS="quote">Could be a jdm h22 with jdm auto trans swap.</TD></TR></TABLE>
I said that.
Jesse_Boyer
12
Dec 24, 2024 02:21 AM
93egtypeR
24
Aug 5, 2010 01:04 PM
jaxx4k
Dec 6, 2004 07:25 PM
sutekidane
Aug 6, 2004 11:15 AM
wu tang
Apr 5, 2003 07:00 PM
