ignition problems
Old Dec 17, 2005 | 08:19 PM
Rudelude22's Avatar
Default ignition problems
My car the other day threw code 15 ignition problem i followed the helms directly step by step and still got nothing, i took it to a shop they said the dizzy might be bad so i got a new one, still nothing, they think i got a wiring problem but i need to know what pin for the ECU harness is for the ignition. thanks and if anyone has any ideas let em know.
and also i jumped the wire that leads to the coil and i got no spark.....
Old Dec 17, 2005 | 08:44 PM
SteveoBA8's Avatar
Default Re: ignition problems (Rudelude22)
Are you getting 12 volts from the yellow wire on the 2prong dizzy connector?
If no then test your coil and we will go from there on the flow chart.
If your getting 12 volts then measure voltage individually between A21(+), A22(+) ecu terminals( ecu pins) and A26(-). Is there 10volt's?
Modified by SteveoBA8 at 9:55 PM 12/17/2005
Old Dec 18, 2005 | 07:01 AM
Rudelude22's Avatar
i checked the 2 wires on the dizzy then i checked the resistance on the coil all good.....i even tried a different dizzy nothing. So im thinking it might be a break in a connection somewhere or even the crank sensor gone bad, but my mechanic said it inside the dizzy, is he right. Any input is much appreciated.
Old Dec 18, 2005 | 10:33 AM
SteveoBA8's Avatar
Default Re: (Rudelude22)
So you are getting 12volts from the yellow wire? Just tell me your email so i can send you the cel flow charts so i dont have to type every step, you either have an open wire or it tells you to substitue an known good ecu, the section i will send you covers all cel flow charts for future help in diagnosis.
Old Dec 18, 2005 | 04:16 PM
Rudelude22's Avatar
Rudelude22@hotmail.com
thanks homie!
Old Dec 18, 2005 | 04:26 PM
SteveoBA8's Avatar
It's been sent mang.
boostedhearts
Oct 28, 2011 02:08 PM
senor honda
Classic Hondas
Dec 23, 2010 12:12 AM
RyanJC
Jan 5, 2010 06:46 PM
crx2ner
Mar 29, 2006 08:59 PM
Guru Designs
May 13, 2005 10:31 AM
