Code 15 help please!
Old Dec 15, 2005 | 09:11 AM
Rudelude22's Avatar
Default Code 15 help please!
my car is throwing a code 15, its a 92 si with jdm h22, ive already searched, and i got a helms it says check resistance on coil i did that its ok, check the the two wires coming off dizzy. they are good. Helms says check ICM, i replaced it, along with cap and rotor, but it says hook a tester up to ECU to check if its bad, i dont have one but im afraid it is bad, anyone here ever have this problem?
Old Dec 15, 2005 | 09:29 AM
SteveoBA8's Avatar
Default Re: Code 15 help please! (Rudelude22)
Reset the ecu, see if you get the same code. 15 is a problem in the ignition output signal circuit. Are you using a usdm external coil dizzy or the jdm internal coil dizzy. Are you using a p13 ecu?
Old Dec 15, 2005 | 09:57 AM
Rudelude22's Avatar
im using a h23 external coil, with an h23 ECU.
Old Dec 15, 2005 | 09:59 AM
SteveoBA8's Avatar
Default Re: (Rudelude22)
get an h22 ecu P13, did you re-use your h23 engine wiring harness? Make sure your getting 12volts from the yellow wire in the 2prong dizzy connector
Edit: you can download a free fsm off the net from superhonda.com in the 4th gen faq's, just follow the links, i dont feel like typing you all the way through the flow chart.
Old Dec 15, 2005 | 11:06 AM
Rudelude22's Avatar
on the 2 prong connector i checked the 12 volts and it was good, i have a helms im using...but i was wondering if anyone had this problem im hoping thats its not a bad ECU
mikeszutu
Sep 12, 2008 03:08 AM
Ryan.
Apr 29, 2008 11:48 AM
jchrm80
Dec 20, 2007 12:41 PM
flavah0wnz
Jun 25, 2007 06:40 PM
jonathancrx
Mar 19, 2005 01:33 AM
