code 23
Old Dec 11, 2005 | 04:06 PM
mck26's Avatar
Default code 23
ok ive had code 23 for like 2 months and nothing is changing. I tried to different ecu's, checked for continuity and it was there and also just replaced the actual sensor itself annd still have the code. any ideas. Theres nothing left to test.
Old Dec 11, 2005 | 04:14 PM
SteveoBA8's Avatar
Default Re: code 23 (mck26)
This is in a 4th gen correct? So you got continuity when you checked from the engine harness knock sensor connector and ecu pin D3? Does the cel come on right away after clearing the ecu and starting again or does it come on after driving?
Did you follow a flow chart during testing?
Modified by SteveoBA8 at 5:28 PM 12/11/2005
Old Dec 11, 2005 | 09:14 PM
mck26's Avatar
Default Re: code 23 (SteveoBA8)
it comes on after a few minutes of driving when its completely warmed up. no i didnt do a flow chart, kinda randomly did all of the tests seperately. yes its a forth gen. its a 99 motor using a brand new obd1 knock sensor.
Old Dec 11, 2005 | 10:11 PM
SteveoBA8's Avatar
Check for a bad connection at the ecu,ks,and connections at the passenger shock tower for loose wires. I think the odb1 and obd2 knock sensors are a different shape so the engine harness ks connector may be loose or something, i dunno good luck.
Old Jan 8, 2006 | 03:01 PM
mck26's Avatar
ok, i rewired the knock sensor so i know all connections are good. the sensor itself is only a month old, timing is set correctly, and i have tried 2 different vtec ecus and 1 non vtec. the two vtecs still throw a code. 1 is jdm and one is usdm, one throws code immediately and the other waits like 5 minutes. any ideas?
Old Jan 8, 2006 | 03:33 PM
v4lu3s's Avatar
RTFM
are you using the original shielded wire for the knock sensor?
fusedfish12
May 29, 2014 11:18 AM
R_Machine
Sep 10, 2005 11:59 PM
sir2sol
Apr 1, 2005 04:55 PM
roadawg
Feb 11, 2004 01:10 PM
shadowstylz
Sep 4, 2003 07:45 PM
