engine revs up what is the problem
Old Dec 12, 2005 | 08:55 AM
01_prelude's Avatar
Default engine revs up what is the problem
i drive down the road get ready to slow down. i push the clutch in and the car drops rpm's then increases a little. i mean it goes for say 3000rpm's to idle then to 1500rpm's when i push the clutch in would that be a fast idle control sensor dirty??? that could it be help????
Old Dec 12, 2005 | 04:07 PM
prelittlelude's Avatar
Default Re: engine revs up what is the problem (01_prelude)
try cleaning the fast idle thermo valve on the bottom of the throttle body, and then clean the IAC
Old Dec 12, 2005 | 05:36 PM
01_prelude's Avatar
Default Re: engine revs up what is the problem (prelittlelude)
is that what it sounds like it could be the car has 79,000 miles.thanks for the help
Old Dec 12, 2005 | 06:27 PM
roller3804's Avatar
Check the idle speed control valve..
And when the RPM goes up and down is that if u just hold that clutch in and leave your feet off anything else but the clutch?
HPrelude1992
Feb 1, 2015 09:14 PM
brian323is
Mar 15, 2010 11:17 AM
cloudconnected85
Sep 21, 2008 07:46 PM
ringgold
13
Aug 9, 2005 10:03 AM
hondaracing1
May 15, 2004 09:39 PM
