PCV valve!!!
Old Dec 28, 2005 | 04:42 PM
alleyezonme's Avatar
Default PCV valve!!!
Okay I did a block swap and i forgot to write down where the pcv valve goes on the h22. I know I know, right on top of the manifold!!! But where does the hose that connects to the valve go to??
Old Dec 28, 2005 | 05:13 PM
The Weather Man's Avatar
To the intake manifold.
Old Dec 28, 2005 | 09:02 PM
Default Re: (TheKINGPin)
ummmmmmmmmmmmm yea? which stem?
Old Dec 28, 2005 | 11:41 PM
98vtec's Avatar
moderator emeritus
Default Re: PCV valve!!! (alleyezonme)
driver side
Old Dec 29, 2005 | 11:21 AM
Default Re: PCV valve!!! (98vtec)
which one? there are two stems off the intake manifold on the drivers side of it.
does anyone have any pics?
Old Dec 29, 2005 | 11:31 AM
SpeedFreak77's Avatar
It connects on the front of the intake manifold near the center, look for a nipple that is approximately the same size in diameter as the pcv valve.
Old Dec 29, 2005 | 01:36 PM
lude98SH's Avatar
If it stops rainin ill get u a pic
Old Dec 29, 2005 | 03:43 PM
SteveoBA8's Avatar
Default Re: PCV valve!!! (lude98SH)
or you could look in the faq's, h22 vacuum diagram
Old Dec 31, 2005 | 06:58 AM
Default Re: PCV valve!!! (SteveoBA8)
that sounds like a plan! thanks guys
SnailSlowDelSol
Feb 21, 2016 09:26 PM
jvonb
Nov 12, 2005 05:26 PM
kamAccord
Aug 30, 2005 06:57 PM
2lobes1engine
May 12, 2004 07:56 PM
tony
Jan 31, 2004 11:21 AM
