stainless lines install
Old Dec 29, 2005 | 11:35 AM
blulude92's Avatar
Default stainless lines install
bad-monkey this question seems to be up ur alley. how would i go about installing braided stainless steel brake lines on my prelude?
Old Dec 29, 2005 | 11:39 AM
chitownrida's Avatar
make sure you use a flare nut wrench to get the line off
Old Dec 29, 2005 | 12:01 PM
Eddiebx's Avatar
u would install them the same way you install regular brakelines, unscrew them and screw them on.
remember to use new washers and bleed afterwards
Old Dec 29, 2005 | 12:41 PM
bad-monkey's Avatar
def use a flarenut, and be careful anyway, those fittings are VERY SOFT!
you have to fit the ss hose on the brackets that are on the OEM lines. if you look at the brackets you'll see how you can attach the SS lines.
other than that, just loosen and tighten, then like eddie said, bleed the air out afterwards.
personally, i didn't notice much from going to SS lines, and they're kind of a pain in the ***, so i went back to stock eventually.
Old Dec 29, 2005 | 03:28 PM
blulude92's Avatar
Default Re: (bad-monkey)
arrite well if u didnt notice much then i wont bother. its money and effort that i dont want to waste
Old Dec 29, 2005 | 11:19 PM
bad-monkey's Avatar
Default Re: (blulude92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blulude92 &raquo;</TD></TR><TR><TD CLASS="quote">arrite well if u didnt notice much then i wont bother. its money and effort that i dont want to waste</TD></TR></TABLE>
it's a very personal thing, some really love SS lines, and others don't--but considering that they SHOULD be replaced every 2 years, i didn't think it was worth the trouble.
vestalfootball72
Dec 7, 2007 06:46 AM
Bbasso
Sep 8, 2003 06:51 PM
Que_Lude
May 13, 2003 12:37 PM
lePetitePrince
Nov 6, 2002 02:33 PM
Regular Series
Aug 16, 2002 08:59 PM
