Broken Ignition.. HELP
Old Jan 1, 2006 | 02:33 PM
plikit's Avatar
Default Broken Ignition.. HELP
My car was broken into a month or two ago and they tried starting it so the ignition got a little messed up. The key still fit fine and turned fine. But now whatever was broken inside came loose and it's pretty much garbage.
I assume I can only get a new ignition from the dealer, or are there alternatives? I want to know how much trouble it'll be to install a new one myself? Does any one know if the ignition can be rekeyed to match the doors/trunk or vice versa? What's my best option?
Old Jan 1, 2006 | 04:52 PM
plikit's Avatar
Default Re: Broken Ignition.. HELP (plikit)
bump
Old Jan 1, 2006 | 04:57 PM
The Weather Man's Avatar
Just look on eBay for a new one - they usually come with a new key; however, you will still have to use your original key for the doors....unless you have an aftermarket alarm system.
Old Jan 1, 2006 | 06:43 PM
Hawkze_2.3's Avatar
Does the key actually have trouble turning inside the cylinder or does it seem like it's only an electrical problem?? The ignition switch is only $40 from Honda and it unbolts from the key cylinder which is a lot more $$$$... Mine went out recently and it was an easy fix.
Old Jan 1, 2006 | 06:52 PM
plikit's Avatar
Default Re: Broken Ignition.. HELP (Hawkze_2.3)
nah its definitely the key cylinder... i figured they were expensive. any other suggestions?
Old Jan 1, 2006 | 07:11 PM
Hawkze_2.3's Avatar
A local junkyard quoted me $40 for a key cylinder. It's $400 or so from Honda....
Old Jan 1, 2006 | 07:51 PM
plikit's Avatar
yeah ive been callin around junkyards. NO ONE has prelude parts...
Old Jan 1, 2006 | 08:17 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by plikit &raquo;</TD></TR><TR><TD CLASS="quote">yeah ive been callin around junkyards. NO ONE has prelude parts... </TD></TR></TABLE>
Well, just a thought here, but the ignition switch that bolts to the end of the key cylinder in the same for a LOT of Hondas...I used one from an old DA Integra on my Prelude for a while. You may want to look into finding an Accord cylinder from the same years as your lude...
Old Jan 2, 2006 | 10:24 AM
flip1199's Avatar
i went and bought a whole new ignition w/key from my local honda salvage yard for 80 bucks when the theives broke mine. they had plenty prelude igntions.
BanzaiBeast
37
Nov 16, 2016 10:44 AM
rugimpy
Aug 21, 2012 10:12 AM
*supersonic*
Sep 4, 2010 12:36 PM
Joelrz
Feb 15, 2010 05:42 PM
Studiox1
Feb 5, 2007 11:17 PM
