BIG problem. Need help
Old Jan 5, 2006 | 07:09 PM
95accordh22a's Avatar
Default BIG problem. Need help
alright guys, i got a problem any input would be appreciated.
i just put my motor back in after complete rebuild. stock bottom end. and crower valvetrain with stock valves and crower cams. go to start the car for the first time and it starts up fine. i have no alternator belt on so i shut the car off, also to pick the idle up a bit. anyways start the car back up again a few mins. later to check the idle and it works fine. prolly about a min in the car shuts off(no loud nooises or anythin)
i figured the battery died so i get the battery charged and try it the next day, still no alt. belt cause i got the wrong one, and it wont start. I am getttin NO SPARK. and i cant figure out way.
Old Jan 5, 2006 | 07:14 PM
mgags7's Avatar
how about you hook up your alternator....running without it could be causing these problems....
why dont you fix obvious things before you worry about other stuff??
Old Jan 5, 2006 | 07:24 PM
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">how about you hook up your alternator....running without it could be causing these problems....
why dont you fix obvious things before you worry about other stuff??</TD></TR></TABLE>
well i got the wrong alternator belt, but if the battery is fully charged than it shouldnt even matter
Old Jan 5, 2006 | 09:27 PM
ed_1's Avatar
Default Re: (95accordh22a)
I'll go with mgags7, you still need a little bit of help from the alternator to start it up, the battery is fully charged, but you still might need more current, than just the battery itself.
Old Jan 5, 2006 | 09:45 PM
camil212's Avatar
Default Re: (ed_1)
I'd agree, how about putting everything back together completly then try starting it again
Old Jan 6, 2006 | 02:26 PM
Default Re: (camil212)
alright well all of you were wrong like i said
it was the control module(igniter) in the distributor like i thought it was
but thanks anyways
Old Jan 6, 2006 | 02:34 PM
CivicB18C1's Avatar
wrong
Old Jan 6, 2006 | 02:35 PM
CivicB18C1's Avatar
Default Re: (ed_1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ed_1 &raquo;</TD></TR><TR><TD CLASS="quote">I'll go with mgags7, you still need a little bit of help from the alternator to start it up, the battery is fully charged, but you still might need more current, than just the battery itself.</TD></TR></TABLE>
wrong #2
CivicB18C1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by camil212 &raquo;</TD></TR><TR><TD CLASS="quote">I'd agree, how about putting everything back together completly then try starting it again </TD></TR></TABLE>
strike 3... your all out...
Old Jan 6, 2006 | 02:36 PM
CivicB18C1's Avatar
Default Re: (CivicB18C1)
have you guys ever touched a car before?? you dont need the alternator to start ur car. or even to run it if ur battery is good. its not gonna last, but thats not what we are arguing now is it
SlimJim25
Apr 17, 2013 01:09 PM
stocker2shocker91
Mar 22, 2008 03:52 PM
ballerchild
13
Sep 22, 2006 08:04 AM
kyorishin
Jan 20, 2006 01:02 AM
cademan
Jul 13, 2004 07:38 AM
