idle problem
Old Jan 1, 2006 | 07:21 PM
19_lude_s_96's Avatar
Default idle problem
my car idles from 1 to 2 1/2 grand all the time its not the pcv though any thoughts?
going to see if i can diagnos problem tommorow.
Old Jan 1, 2006 | 07:23 PM
The Weather Man's Avatar
vacuum leak. Maybe.
Old Jan 1, 2006 | 07:26 PM
CivicSiDriver02's Avatar
Default Re: idle problem (19_lude_s_96)
I would put money on the Idle Air Control Valve. Mine did the same thing. Unplug it and see what happens. Could be a vacuum leak tho.
Old Jan 1, 2006 | 07:30 PM
Default Re: idle problem (CivicSiDriver02)
unplugged idle air control it just idle up and down faster
Old Jan 1, 2006 | 07:39 PM
Do u have a MIL?
Old Jan 1, 2006 | 07:40 PM
Dougs96SI's Avatar
Any Mods?
Old Jan 1, 2006 | 07:47 PM
Default Re: idle problem (Dougs96SI)
cold air, and exshaust
Old Jan 1, 2006 | 07:48 PM
as in machine shop mill?????
Old Jan 1, 2006 | 07:52 PM
lol, malfunction indicator lamp. (check engine light)
Old Jan 1, 2006 | 08:04 PM
no check engine light (god i fell retarted)
Old Jan 1, 2006 | 08:07 PM
but i just replaced the head 2 days ago, it did it when it was cold but it warmed up and it was fine today i left taco bell bounced it off the chip a couple times and know it revs like that constantly
Dougs96SI's Avatar
My idle went to hell a little while after I installed my CAI, header, and exhaust. The basic bolt ons will throw your air fuel ration off just enough to screw with your idle. Normally the car will run fine, but it becomes choked up during idle.
Old Jan 1, 2006 | 08:13 PM
yeah but it idles fd up all the time
Old Jan 1, 2006 | 08:15 PM
Haha, dont worry about it. I was just too lazy to type it out. lol Well anyway, according to helms if you have no MIL you are supposed to hold the engine at 3k with no load untill your radiator fan comes on. Then, release the throttle and disconnect the the wire to the IACV. If there is no reduction in rpm then the IACV is bad. If there is then it could be a few different things. However if you rpms are fluctuating you likely wont be able to tell if whether or not there was a reducion in rpm. With all this being said I am starting to lean more toward a vacuum leak somewhere.
Old Jan 1, 2006 | 08:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 19_lude_s_96 &raquo;</TD></TR><TR><TD CLASS="quote">but i just replaced the head 2 days ago, it did it when it was cold but it warmed up and it was fine today i left taco bell bounced it off the chip a couple times and know it revs like that constantly</TD></TR></TABLE>
lol, it could be the taco bell
Old Jan 1, 2006 | 08:24 PM
you never know ive had so many problems with this car lol, but hopefully ill find the problem tommorow but if not im picking up another prelude next week 92
SI sweet
Old Jan 1, 2006 | 08:41 PM
i also read somewhere that a low coolant level can make it idle funny has anyone heard about that????
Old Jan 1, 2006 | 08:51 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 19_lude_s_96 &raquo;</TD></TR><TR><TD CLASS="quote">i also read somewhere that a low coolant level can make it idle funny has anyone heard about that????</TD></TR></TABLE>
If your coolant is not bled and has air bubbles it can cause an erratic idle.
Old Jan 1, 2006 | 10:18 PM
Default Re: idle problem (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheKINGPin &raquo;</TD></TR><TR><TD CLASS="quote">vacuum leak. Maybe.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dougs96SI &raquo;</TD></TR><TR><TD CLASS="quote">My idle went to hell a little while after I installed my CAI, header, and exhaust. The basic bolt ons will throw your air fuel ration off just enough to screw with your idle. Normally the car will run fine, but it becomes choked up during idle. </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">
If your coolant is not bled and has air bubbles it can cause an erratic idle.</TD></TR></TABLE>
It wasn't any of this ^, it ending up being IAC and whatever is connected to the IAC through coolant lines thanks for your help
Old Jan 1, 2006 | 10:19 PM
problem fixed!!!!!!!!!!!! it makes me happy when things work out.........sigh..........
Old Jan 2, 2006 | 05:13 AM
PreludeH22vtec's Avatar
after reading this im a little lost, i have the same problem with mine but i really dont know anything about all the parts that bolt onto the engine, so would anybody be kind enough to give me a basic step by step on what im actually supposed to be fixing, or i link to a write up would be very helpfull.
cheers
Old Jan 2, 2006 | 11:05 AM
AnthonyG2003
Guest
Posts: n/a
Default Re: (PreludeH22vtec)
I had the same problem for the past 3 months and could never figure it out and could never get anyone to help me with it at all. I ran across the 92lude.com site and there was a "IACV Mod" that you could do and when I did it...My problem was fixed. So I think if anyone is having the idleing problem, then they need to try to mod off of 92lude.com ... IT WORKS!
Old Jan 3, 2006 | 07:33 AM
Default Re: idle problem (silverlude15)
so which one do i need to play around with???
Old Jan 4, 2006 | 07:37 AM
Default Re: idle problem (PreludeH22vtec)
anyone?
Old Jan 4, 2006 | 04:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreludeH22vtec &raquo;</TD></TR><TR><TD CLASS="quote">anyone?</TD></TR></TABLE>
I'm anyone you need to (mess) with IAC which is the one on the front of your plenum towards engine
stuckinmud
Aug 14, 2009 08:32 AM
Thatssojdm
Aug 5, 2008 07:59 PM
vdawg559
Jun 11, 2008 04:31 AM
Victor
Dec 1, 2004 10:29 AM
b16acrxer
Aug 31, 2004 09:02 AM
