check light on!!!!
Old Jan 3, 2006 | 02:09 PM
dtran002's Avatar
Default check light on!!!!
hey guyz, today i took my car for a drive and i notice that my car is much much more quieter than normal, usually it would be hella loud cuz of 2.5 straight pipe, and it seem like it really weak, and it throw me a cell code 43, which is fuel supply system circuit, is that correct? and wat the heck is that mean...i tried to seach but the search thing said temp. not avail. thanks alot
Old Jan 3, 2006 | 02:15 PM
SteveoBA8's Avatar
Default Re: check light on!!!! (dtran002)
Reset the ecu, drive and see if it comes on and if its the same code. 43 is Fuel supply system=problem with Ho2s circuit(o2 sensor circuit) or fuel supply. I can email you the flow chart if needed.
Old Jan 3, 2006 | 02:20 PM
dtran002's Avatar
Default Re: check light on!!!! (SteveoBA8)
how u reset the ecu? take out the batery cable???? and wat flow chart is that? bunch of codes???
Old Jan 3, 2006 | 02:27 PM
CliffBurton's Avatar
Unplugging the battery for a little while should do the trick
Old Jan 3, 2006 | 02:28 PM
dtran002's Avatar
Default Re: check light on!!!! (CliffBurton)
thanks gonna try that now and see if it throw again
Old Jan 3, 2006 | 02:39 PM
SteveoBA8's Avatar
just remove the clock/radio fuse in the engine compartment for 10 seconds or remove the negative battery cable, a flow chart is a diagnostic list of things to check for codes
Old Jan 3, 2006 | 02:53 PM
dtran002's Avatar
o ok, did that for awhile, then start the car drive around, it still throw me that code...kinda weird that the car run smoother and quieter, not that im complainin, i was kinda glad it run smooth and quieter but the check light is botherin me
btws, i have that chart, thanks though
Old Jan 3, 2006 | 02:58 PM
SteveoBA8's Avatar
cool, let us know whats causing your cel.
Old Jan 3, 2006 | 03:04 PM
dtran002's Avatar
hahahaha i was hopin u guyz would tell me wat might be wrong, i wont be able to get it check until next week or so cuz my mechanic went on vacation
Old Jan 3, 2006 | 03:09 PM
SteveoBA8's Avatar
If you have the flow chart you could fiqure it out with a multimeter
Old Jan 3, 2006 | 03:19 PM
dtran002's Avatar
ooo hahaha sorry, like i said, iono crap bout these stuff, care to show me how to do it
Old Jan 3, 2006 | 03:23 PM
SteveoBA8's Avatar
wait till your mech is back, i cant show you over the net
Old Jan 3, 2006 | 03:28 PM
dtran002's Avatar
ok lol, but meanwhile i can hit vtec and it wont damage much about my engine right?
Old Jan 3, 2006 | 04:14 PM
SteveoBA8's Avatar
i wouldnt try it since it is the fuel supply, you dont want to lean out and burn up your perty type s pistons now do you
Old Jan 3, 2006 | 04:18 PM
dtran002's Avatar
hehehe ic, thanks alot for the info
derrickjon
Oct 23, 2016 04:17 AM
PDXHatchback
Jan 1, 2007 12:32 PM
91 ex
Sep 11, 2006 06:27 AM
h22xcivic
Apr 27, 2006 07:51 PM
bboychris
Sep 17, 2002 08:56 PM
