knock sensor code
Old Jan 2, 2006 | 09:12 AM
acclude-vtec's Avatar
Default knock sensor code
check engine lite is on and the code is knock sensor...i replaced it twice one with was used the other new from the dealer....reseted the ecu but still get that code...i also rewired straight to the ecu to pin d3...what can it possible be????h22a vtec engine...h22a trany (m/t)...h22a vtec ecu (p13)
Old Jan 2, 2006 | 10:23 AM
SteveoBA8's Avatar
Default Re: knock sensor code (acclude-vtec)
Code 23 is the knock sensor, did you use a shielded wire? Check for continuity from the engine harness ks connector and the ecu pin D3, if you have continuity it could be your ecu, non shielded wire, clean the threads on the knock sensor before installing.
Old Jan 2, 2006 | 10:42 AM
IHateJDM's Avatar
Default Re: knock sensor code (SteveoBA8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SteveoBA8 &raquo;</TD></TR><TR><TD CLASS="quote">clean the threads on the knock sensor before installing.</TD></TR></TABLE>
make sure you check this, the sensor is self-grounded.
Old Jan 2, 2006 | 11:00 AM
ed_1's Avatar
Default Re: knock sensor code (IHateJDM)
Did you torque it down to manufacture specs? If not that might be your problem.
ek4 sir civic
Jun 28, 2007 07:09 PM
tc_gts
11
May 4, 2005 05:26 AM
LaosIntegra
Apr 18, 2005 09:33 PM
ddong2lee
Mar 4, 2004 05:06 AM
clean99teg
Sep 21, 2002 05:43 PM
