cel code 43: what to do?
Old Apr 13, 2006 | 11:43 AM
951dc5's Avatar
Default cel code 43: what to do?
93 prelude vtec; After engine degrease to rinse it off. Start the engine and it starts to bog like there is not enough spark or fuel. Let everything dry and found that there is water inside the well of spark plug hole number 2. Clean water out and it's still does the same. Is there anything else i need to look or check for with cel code 43. Thanks
Old Apr 13, 2006 | 11:57 AM
syntax.'s Avatar
Default Re: cel code 43: what to do? (Prelude951)
Its usually your o2 sensor, but since it started after washing the engine bay, check for loose connections at the o2 or frayed wires. If the wires look good then replace the o2 with a new one. i have had bad experiences with bosch o2's on hondas, try and get a denso, ntk, or walker.
Old Apr 13, 2006 | 05:39 PM
951dc5's Avatar
Default Re: cel code 43: what to do? (syntax420)
o2 from the exhaust you mean? got any link to a place where it sells o2 for cheap. Thanks
Old Apr 13, 2006 | 06:07 PM
jakks20's Avatar
Universal Bosch O2 sensor on ebay for $26.99 shipped from a seller named evalero(I believe). Just have to wire your sensor plug on to it. Even comes with the "butt connectors". Just bought one last week.
Old Apr 13, 2006 | 07:53 PM
951dc5's Avatar
Default Re: cel code 43: what to do? (jakks20)
Bosch O2 sensor?? didnt syntax420 mention he had bad experience with bosch o2.
Old Apr 14, 2006 | 02:37 AM
syntax.'s Avatar
https://honda-tech.com/zerothread/1557854
So maybe you just need to shorten up the wires in order to use a bosch universal and not get code 43 back. Good luck
Old Apr 14, 2006 | 05:42 AM
94vtecmn's Avatar
Default Re: (syntax420)
If your having issues after cleaning the engine after water was found in the spark plug well, get new plug wires, I had this happen, and that's all it was. My wires were old enough to need to be replaced anyway.
Old May 22, 2006 | 05:52 AM
jmayhew's Avatar
Default Re: (94vtecmn)
any more info on this code....
i get a CEL 43 about 1-2x per month.
& i have a funny idle...sometimes its fine & other times it will slowy rise to just about 1k then fall to around 300 & then go back to normal for a sec & the start to slowly climb again
Sometimes its hard to start too...
things i've done/tried.
new 02 (denso)
put on a Fuel pressure gauge & the FPR looks to be working fine.
new plugs (NGK)
new wires (NGK)
new Cap
using a walbro 255
new fuel filter
we've plated with the IAC but my friend still thinks it might be the IAC or the fast idle on the throttle body.
vacuum leak???
we are running out of ideas.
would the length of the wires on the denso O2 really make that much of a difference?
i'm going to switch to a chipped P28 insetad of the P13 i'm using now...my car ran & idled better on my friends chipped p28...but there is still something wrong cause my friends H22 EG idles perfect on that chip & mine still floats around.
traxxasx
Apr 16, 2008 06:34 AM
CivicRider011
Dec 17, 2006 10:16 AM
boostinh22
Nov 29, 2005 11:15 AM
teg2000gs
Oct 26, 2004 11:02 AM
fast[R]
Apr 24, 2002 04:58 PM
