using to much oil
Old Apr 10, 2006 | 05:29 PM
20_00_lude's Avatar
Default using to much oil
i was wondering if anyone has a problem with their engine using oil. there are no apparent leaks yet somehow the oil always seems to be low. i had a honda dealership check it and they saideverything was fine. i also like to run my car a little more than i should......
Old Apr 10, 2006 | 07:41 PM
petern101's Avatar
Default Re: using to much oil (20_00_lude)
vtec uses oil, and h22's have always been known to eat oil
just make sure the levels are ok and that will help
Old Apr 10, 2006 | 10:06 PM
lude98SH's Avatar
Default Re: using to much oil (petern101)
First of all H22s eat oil. Check your plugs and see if they are sooty. But there are a few things that may play into how much oil it burns. How many miles on the car ? An older motor will typically burn more oil than a newer one. What type of oil of you using ? How is your compression ? Low compression may be a sign of bad rings which would cause the oil to blow by and burn in the combustion chamber. Basicly you just have to keep an eye on the problem, check your oil level often. Aviod hitting vtec very often.
Look at this thread it may help.
https://honda-tech.com/zerothread?id=1424858
Old Apr 11, 2006 | 11:56 AM
NAmodified's Avatar
Default Re: using to much oil (lude98SH)
its a dam prelude motor, my h22a burns no oil!
Old Apr 11, 2006 | 01:38 PM
20_00_lude's Avatar
Default Re: using to much oil (NAmodified)
the car is a 2000 with 89k and i have no idea what the compression is at right now......i think i need new wires, plugs, distributor, and rotor....honda told me no aftermarket but i have plans on going the way.....should i stay with oem or upgrade??
Old Apr 12, 2006 | 10:06 AM
lude98SH's Avatar
Going aftermarket with just bolt ons wont really affect your oil burning. I would check your compression and see if everything is ok before you start throwing money into aftermarket parts.
Old Apr 12, 2006 | 10:08 AM
tytyguy's Avatar
vtec, will eat all your oil.
highwhey
Nov 11, 2010 05:53 AM
210jdmgsr
Aug 15, 2007 03:55 PM
joshalee
Aug 26, 2004 12:04 AM
osuPrelude
Oct 22, 2002 05:24 PM
PY2KITR1060
May 4, 2002 01:30 PM
