Poly Motor Mount Inserts
Old Apr 18, 2006 | 11:49 AM
kornerk12's Avatar
Default Poly Motor Mount Inserts
I just purchased a set of Energy Suspension Motor Mount Inserts. The company was out of the black ones and only had red so I said to go ahead and send them. Under the description it said:
Unlike the RED bushings - the graphite serves to help self lubricate these bushings and keep them from squeaking!
Does this really matter for motor mount or will i have to lubricate them ?
Old Apr 18, 2006 | 05:04 PM
BB6-213's Avatar
I put some assembly lube on mine just to help avoid squeaks.
Old Apr 18, 2006 | 05:08 PM
hu's Avatar
hu
I would use some sort of lube as well with the red ones.
Old Apr 18, 2006 | 06:23 PM
kornerk12's Avatar
Default Re: (hu)
It didnt come with any type of lube... what exactly should i use and where do i place the lube? Also how often should i re lube them ?
Old Apr 18, 2006 | 08:07 PM
M2B4's Avatar
Default Re: (kornerk12)
you will know when they need relubing. i read to relube them atleast every year
Old Apr 19, 2006 | 05:04 AM
integra15's Avatar
Default Re: (M2B4)
I could see using lube with suspension bushings, but is it nesessary with motor mounts?
Old Apr 19, 2006 | 05:24 AM
KENLUDE97's Avatar
Default Re: (integra15)
Its prolly not needed with motor mounts. They don't "move" like say sway bar bushings or other suspensions bushings.
But if you really want to lube them you can use any type of grease.
Old Apr 19, 2006 | 06:38 AM
Daemione's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra15 &raquo;</TD></TR><TR><TD CLASS="quote">I could see using lube with suspension bushings, but is it nesessary with motor mounts?</TD></TR></TABLE>
Nope. I've got the red ES motor mounts. Didn't use any lube when I installed them, and I've never heard a single squeak from them. Been installed about 2 years now.
Old Apr 19, 2006 | 07:09 AM
Qveon's Avatar
Default Re: (Daemione)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daemione &raquo;</TD></TR><TR><TD CLASS="quote">
Nope. I've got the red ES motor mounts. Didn't use any lube when I installed them, and I've never heard a single squeak from them. Been installed about 2 years now.</TD></TR></TABLE>
Same here
Old Apr 19, 2006 | 09:40 AM
kornerk12's Avatar
Default Re: (Qveon)
ok thanks guys. Big help
airmaxbri
Oct 8, 2010 11:27 AM
no1_suspek
Honda Civic (2001 - 2005)
Sep 21, 2010 01:53 AM
ctr status
May 8, 2006 11:24 AM
IntegraTionR
Aug 26, 2005 05:34 PM
2000si
Nov 6, 2002 01:49 PM
