msd ignition...
Old Apr 16, 2006 | 12:12 AM
zexifiedlude's Avatar
Default msd ignition...
ok after my dyno pulls it seems i need to work a bit on my ignition, so i want to go all msd... can someone give me parts numbers to what items i need to buy
i wana go with new wires, cap, rotor, coil, and probably a 6al box. any recomendations or suggestions are more then welcome. thanks
Old Apr 16, 2006 | 09:25 AM
connvict's Avatar
I have a digital6 plus up for grabs.....$150.
Why do you want the 6al vs. the digital6? The 6al is old technology. Uses little pills for the rev limiter among other things. Also, you may have to buy a separate unit for your tach to work (not 100% on that).
The Digital6 wires right in in like 5 mins. It has a built in two step rev limiter and dial type adjustments on the end of the box.
Get the BlasterSS coil.
I don't think the make a rotor.....
Just ask for the wires for your car, you will have to build your coil wire......
Ask for the cap. I remember looking for one for my 5th gen, and they didnt make one at the time.....
Hope it helps...
Michael
Old Apr 16, 2006 | 09:53 AM
Hawkze_2.3's Avatar
Default Re: msd ignition... (zexifiedlude)
MSD will be a waste of your time and money...unless they finally make an H-series Pro-billet distributor.
Old Apr 16, 2006 | 01:20 PM
K-Spec's Avatar
I recommend not to purchase MSD...I had a Digital6 plus go out on me 3 times and I shipped it into service twice. The Blaster SS coil is also crap, it died on me on the way home from school and went through two of the coils. MSD =
Old Apr 16, 2006 | 07:55 PM
so what should i do to upgrade my ingnition
Old Apr 16, 2006 | 08:32 PM
Hawkze_2.3's Avatar
Default Re: (zexifiedlude)
Why do you need to upgrade it?? What problems are you having?
Old Apr 17, 2006 | 08:42 AM
cause there are an insane amount of dips in my dyno chart witch my tunner said was from ignition breaking up. so i wanted to make it better
Old Apr 17, 2006 | 08:47 AM
syntax.'s Avatar
have you done the normal tune up stuff first? new ngk plugs wires and oem cap and rotor?
Ive seen 300whp+ setups using the stock ignition no problem.
Old Apr 17, 2006 | 08:53 AM
Hawkze_2.3's Avatar
Default Re: (syntax420)
/\/\Yeah, just replace it with OEM stuff.
I spent the $$$ and did my ignition like you want to and it was 90% a waste. I did Magnecor wires, Iridium plugs, Crane cap and rotor, MSD 6AL and Blaster SS coil.
Now I'll be replacing the Magnecor wires with NGK because they don't fit very well, the MSD box crapped out randomly and left me stranded and the SS coil is no better than the OEM coil.
The only thing I would actually reccomend upgrading is the distributor cap to a transparent one because it makes it a lot easier to see what's going on with your engine. That's my opinion...
Old Apr 17, 2006 | 08:56 AM
syntax.'s Avatar
Default Re: (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">The only thing I would actually reccomend upgrading is the distributor cap to a transparent one because it makes it a lot easier to see what's going on with your engine. That's my opinion...</TD></TR></TABLE>
yeah right, you just like the pretty colors
ricer
Old Apr 17, 2006 | 09:02 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by syntax420 &raquo;</TD></TR><TR><TD CLASS="quote">
Guilty as charged.
Old Apr 17, 2006 | 11:55 AM
connvict's Avatar
Thanks for totally killing my attempt to sell my stuff BTW...... :-P
Old Apr 17, 2006 | 06:32 PM
LudaChris's Avatar
Default Re: (connvict)
Stick with the stock ignition as much as possible not unless your going over 125 shot or more. Like the others have suggested, just maintain your stock parts, 2 step colder plugs, wires, cap, rotor. Just get the MSD adjustable timing control and it will work with your stock setup, I just did one yesterday. This way, you can retard your timing whenever you want depending on weather conditions. Good luck.
Old Apr 17, 2006 | 06:37 PM
tcontesh's Avatar
Default Re: (LudaChris)
im so glad this subject was covered, because I was going to blow alot of money on all MSD ignition ****. All that I run on my Turbo setup is ngk copper plugs and MSD 8.5mm wires and it still works just fine. does anyone disagree?
Old Apr 17, 2006 | 06:55 PM
ok im glad i got real answers instead of "search" but yeah i havnt changed my cap and rotor in like a years, and ive been using the same 8.5mm msd wires for like 3 years now so i guess its time to change that too.. but plugs are only about a week old
Old Apr 17, 2006 | 06:56 PM
ohh and where can i get a clear cap, i like cool ricer stuff too lol
Old Apr 17, 2006 | 08:33 PM
VtecFreePrelude's Avatar
i just saw a clear cap at auto zone so you could probably get it there
Old Apr 17, 2006 | 08:58 PM
ChrisRicketts's Avatar
Default Re: (VtecFreePrelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecFreePrelude &raquo;</TD></TR><TR><TD CLASS="quote">i just saw a clear cap at auto zone so you could probably get it there</TD></TR></TABLE>
for an h22? i've never seen aftermarket caps for h22's.......can you really get them at autozone?
Old Apr 17, 2006 | 09:03 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zexifiedlude &raquo;</TD></TR><TR><TD CLASS="quote">ohh and where can i get a clear cap, i like cool ricer stuff too lol</TD></TR></TABLE>
You should be able to use a Civic or Accord cap... Search the internet, there's lots of them.
Old Apr 18, 2006 | 09:50 AM
DIRTYsouthBB6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by connvict &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for totally killing my attempt to sell my stuff BTW...... :-P</TD></TR></TABLE>
hahaha
Old Apr 18, 2006 | 09:59 AM
syntax.'s Avatar
i'm sure you will be able to unload that stuff on ebay and get a decent price. they work on a lot of different imports, not just preludes or hondas. good luck
Old Apr 18, 2006 | 10:59 AM
That one is made by Mr. Gasket Performance Group
O'Reilly Auto Parts carries a transparant red MSD one as well.
Moroso also makes a transparant blue one.
Mitsuzuki
Nov 5, 2007 12:12 PM
turbohf
May 21, 2006 11:02 PM
roterx7
Apr 1, 2006 05:23 AM
jedubz
Aug 24, 2005 06:00 PM
Hatch_Back_97
Aug 5, 2005 10:45 AM
