Rubbing Issue
Old Aug 31, 2006 | 08:34 AM
Simple_Sauce's Avatar
Default Rubbing Issue
Alright well I'm running 17x8 SSR Comps with 225/45/17 tires on my 5th gen. In the front I have Toyo Proxes4 and in the rear its Yokohama ES100 My car is rubbing like crazy even on the stock suspension. Its the rear thats rubbing the most. What can I do? I asked around and people have been saying 205 series tires with a fender roll while others are saying that wont solve my problem and I really dont want to buy new tires because the tires on these are brand new. Someone else also said if I get tein SS suspension it will bring it closer in which will give me enough clearance. I also want to lower my car back to the Eibach Pro-kit and Bilsteins that I had with no problems. Thanks in advance.
Old Aug 31, 2006 | 08:47 AM
prelude1897's Avatar
Default Re: Rubbing Issue (Simple_Sauce)
You have too wide of a tire..You should've gone with a P215/40R17 tire
Old Aug 31, 2006 | 09:12 AM
done up bb6's Avatar
Default Re: Rubbing Issue (prelude1897)
i had 215/45/17 on 17x7 with a 37 offset. i was rubbing also. so i went with some 215/40/17 and its alot better now. i rub every so often but not all the time like i use to.
Old Aug 31, 2006 | 09:21 AM
Default Re: Rubbing Issue (done up bb6)
what suspension are you running?
Old Aug 31, 2006 | 09:59 AM
classified's Avatar
Honestly it's pointless for anyone to offer any advice without knowing what you are running for an offset...
Old Aug 31, 2006 | 10:25 AM
nonvteclude's Avatar
Default Re: Rubbing Issue (spirctsae)
well if you are rubbing on the inside you can simply get some wheel spacers to push them out. that would be the easiest and cheapest fix
Old Aug 31, 2006 | 10:54 AM
i believe my offset is either +35 or +38. The tire is rubbing on the inside part of the outer fender. I'll get pics.
Old Aug 31, 2006 | 11:39 AM
classified's Avatar
Default Re: Rubbing Issue (nonvteclude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvteclude &raquo;</TD></TR><TR><TD CLASS="quote">well if you are rubbing on the inside you can simply get some wheel spacers to push them out. that would be the easiest and cheapest fix</TD></TR></TABLE>
Don't listen to this individual it's clear he's very confused.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Simple_Sauce &raquo;</TD></TR><TR><TD CLASS="quote">
Your problem lies in both your tire width and your offset. The factory offset on your lude is +55 and most(not all) people don't bother running offsets below +42 because it usually causes rubbing with any tire wider than 215. You got to low of an offset and to wide of a tire. You can try using a more narrow tire and rolling the fenders but I'm willing to bet you'll still have rubbing problems with that setup.
Old Aug 31, 2006 | 11:43 AM
So either way im screwed? Could someone link me to a place to show me how to roll my fenders.
Old Aug 31, 2006 | 11:52 AM
classified's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Simple_Sauce &raquo;</TD></TR><TR><TD CLASS="quote">So either way im screwed? Could someone link me to a place to show me how to roll my fenders.</TD></TR></TABLE>
I wouldn't say screwed. I've seen much more difficult things made to fit. The link below is the type of tool used to roll fenders. I'd actually get a shop with one to do it for you unless you can get your hands on one of them to borrow. You would need to actually heat the paint around the edge of the lip before rolling otherwise you crack paint and it isn't any fun.
Some will tell you to heat the fenders yourself and use the leverage of the car and a baseball bat to do it but it's risky and rarely looks as good.
http://www.tirerack.com/access...p.jsp
b17itr
May 7, 2012 11:07 AM
AdeJong 03
Wheels
Apr 6, 2010 11:17 AM
MyHotsh
May 30, 2008 06:41 PM
JohnnyBoy
Mar 16, 2002 10:05 AM
