Throttle Response
Old Aug 31, 2006 | 09:14 AM
k_lude's Avatar
Default Throttle Response
just got my car back from the shop..had 8 bent valves..all fixed and runs good except throttle response is really bad...on 3rd and 4th the rpm laggs and doesnt jump as usually it takes a couple of seconds before it does it. is it the idle screw the flat one on the throttle or is it the wire for the throttle...any help will be appreciated.
Old Aug 31, 2006 | 09:48 AM
InvaderTrax's Avatar
Idle screw wouldn't effect how your car runs above idle. Maybe the mechanic didn't get your timing quite right after reassembly
Old Aug 31, 2006 | 12:00 PM
bluedlude's Avatar
Default Re: (InvaderTrax)
which gen prelude do you have?
Old Aug 31, 2006 | 12:31 PM
Daniel M's Avatar
What invadertraxx said...or
what does the slack on your throttle cable look like? Maybe you had it tighter then stock before you sent it to the mech's?
Old Sep 1, 2006 | 12:48 AM
k_lude's Avatar
Default Re: (Daniel M)
alrite guys...rite after the mechanic i took it to another one because i did notice the cable was to tight..he checked and said it was also to tight...my idle was at 1500rpms...so we droped it down to normal 6-7000rpms...i was there when the first mechanics first started my engine...they didnt do the timing i totally forgot thanks im gonna check up on it tommorrow...but i was just wondering guys can there also be anything else?
Old Sep 1, 2006 | 12:49 AM
k_lude's Avatar
i have a fifth gen...bone stock.
Old Sep 1, 2006 | 01:07 AM
lude1888's Avatar
Default Re: (k_lude)
Just wondering how do you know if you have bent valves. I think I might have them too in my h23a as the engine idle doesn't sound so quiet. It sounds the same as before and after I did the engine swap, so could it be an external part. Are the 4th gens normally really loud idling cars.
Old Sep 1, 2006 | 10:15 AM
hulk_22's Avatar
check your dizzy? the rotor and cap!
Old Sep 1, 2006 | 06:49 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: (hulk_22)
sounds like could be bad timing or bad valve adjustment
Old Sep 2, 2006 | 07:31 PM
k_lude's Avatar
Default Re: (cb7-R)
bent valves....do a compression test or leak down test and it will tell the results if theres nothing wrong with the tests its mostly ignition
alrite did timing and is now fine...how is there a bad valve adjustment...my motor has ticking noise but sounds mostly like my injectors...should i do another valve adjustment?
Old Sep 2, 2006 | 08:19 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k_lude &raquo;</TD></TR><TR><TD CLASS="quote">bent valves....do a compression test or leak down test and it will tell the results if theres nothing wrong with the tests its mostly ignition
alrite did timing and is now fine...how is there a bad valve adjustment...my motor has ticking noise but sounds mostly like my injectors...should i do another valve adjustment?</TD></TR></TABLE>
Because if the valves are too loose your car will accelerate like its stuck in mud,no power whatso ever. I dont know if thats your problem, Im just shooting out ideas.
Old Sep 2, 2006 | 09:16 PM
k_lude's Avatar
Default Re: (cb7-R)
no thats good...any help is good....im all out of ideas rite now....theres ticking noises of somewhat but they seem to be injectors...im just wondering if it might be loose valves..i used to have some but they didnt quite sound like that...
Old Sep 2, 2006 | 09:20 PM
Hawkze_2.3's Avatar
Yeah, I also vote for timing or valve lash. Double check those things for sure...
therealmccoy
Jun 8, 2018 09:31 AM
FATKID87
Honda CR-V & Element
Mar 26, 2014 07:52 AM
cdmef
Jul 3, 2011 06:03 AM
emooheo
Mar 23, 2007 02:34 PM
GruvyTune
Aug 18, 2001 09:15 AM
