Nitrous help
Old Aug 25, 2006 | 05:14 PM
wrx'n you's Avatar
Default Nitrous help
How much nitrous do u guys think i can safely run with my setup. i was thinking of a direct port or wet system heres my specs. i was thinking about a 100 shot but i dont know...
Endy 87.5 high comp pistons
11:1 compression
H22 Eagle rods
golden eagle sleeved block
head was machined and all seals replaced
place racing axles and motor mounts
T1R Race headers
Skunk2 Stage 2 Camshaft
Skunk2 Stage 2 springs
Skunk2 Stage 2 retainers
Skunk2 Stage 2 cam gears
RC fuel pressure regulator
Custom 2.5" exhaust piping all the way back with Apexi muffler
oh and i am currently dyno tuned with crome
Old Aug 25, 2006 | 05:35 PM
Attaus's Avatar
Make sure you're getting enough fuel, get a step or two (if you're going 100+) colder plugs, and you should be good.
I'd consult your tuner or get one just to make sure.
Old Aug 25, 2006 | 05:45 PM
wrx'n you's Avatar
Default Re: (Attaus)
yeah, im most def getting a 255 walbro and upgraded injectors. not sure of which size yet. also, should i get it tuned again for nitrous? ive been hearing people saying not to tune it and just retard my timing a few degrees or something.
Old Aug 25, 2006 | 06:00 PM
94draglude's Avatar
if you have the best tune in the car with the current setup start low 75-100 on the dyno then check your data log or a/f then work your way up. Of course u will need a colder plug. I would start the session running just a bit rich for saftey. I ran a 100 shot 4-5 bottles on a stock h22a closed deck and never blew I just cracked the ring landings in the end but it still ran with a little smoke off the nitrous.
Old Aug 25, 2006 | 06:34 PM
wrx'n you's Avatar
Default Re: (94draglude)
so would i still have to retard my timing and everything?
Old Aug 26, 2006 | 06:40 AM
wrx'n you's Avatar
Default Re: (H.is.for.HEROS)
anyone?
Z0831xiz
Oct 14, 2017 12:52 PM
ctr-ek
May 5, 2009 08:41 AM
NCSTIdriver
Mar 4, 2003 08:38 AM
36Chambers
Dec 23, 2002 10:50 AM
