Bleeding the brakes
Old Aug 27, 2006 | 01:11 PM
RRbound's Avatar
Default Bleeding the brakes
Ok so i have an 86 that i bought for $300 and have fixed a few things to make road worthy. I recently replaced the master cylinder and brake booster. I have started to bleed the brakes according to the manual and using the typical mechanical knowledge that i have. The brakes are not bled all the way.
i'm wondering if there is any faster way or any tricks of the trade. This is my first foreign car as i have had mustangs all my life.
Old Aug 27, 2006 | 01:31 PM
RRbound's Avatar
Default Re: Bleeding the brakes (RRbound)
come on people need some help please.
Old Aug 27, 2006 | 01:40 PM
JSpekBB4's Avatar
bump for a cool dude thats finally getting into a import :-) haha, give it a lil bit, your 2nd gen isn't the most pop prelude, so you gotta wait for someone that has had one or worked on em'
Old Aug 27, 2006 | 02:05 PM
SKDRCR's Avatar
Default Re: Bleeding the brakes (JSpekBB4)
Start with the one farthest away from the master cylinder,
make sure none of the lines are leaking as well.
Old Aug 27, 2006 | 02:13 PM
RRbound's Avatar
Thanks. I have already did that. No leaks found. Guess i just need to perform the same steps until its good. The rear ones don't bleed much though. Just wondering if there was a faster way or anything i'm forgetting as this is my first import car. But any help is much appreciated.
Old Aug 27, 2006 | 03:01 PM
b-inky's Avatar
are you using a vacuum pump for bleeding the lines, best investment ive ever bought for maintenance.
Old Aug 28, 2006 | 06:34 PM
RRbound's Avatar
ok so guess it just took a little more patience and some muscle. Thanks for all input. The brakes are finnaly right. Took the car for a drive and its not too bad. I might just like this car.
90 ef
Oct 29, 2009 12:03 PM
pedroa06
Sep 3, 2009 06:23 PM
dnl_hcktt
Mar 6, 2008 09:49 AM
Filliam H. Muffman
14
Aug 2, 2004 06:24 PM
Terminator Sol
May 17, 2004 08:20 AM
