TECH HELP NEEDED: LIGHTS
Old Aug 29, 2006 | 07:46 PM
JSpekBB4's Avatar
Default TECH HELP NEEDED: LIGHTS
need some help, checked all my fuses... and my headlights don't work, corners don't work, dash lights don't work, basically the parking lights don't work, and also the reg headlights.... If I turn the brights on the brights will work, if you turn on the 4 ways or the blinkers they'll work, and if you press the brakes the rear lights work
only thing that doesn't work is parking lights (including dash lights) and the reg headlights...
any idea what could be wrong?
Old Aug 29, 2006 | 07:52 PM
AnthonyG2003
Guest
Posts: n/a
Default Re: TECH HELP NEEDED: LIGHTS (JSpekBB4)
could be the main relay...take your abs relay and plug it into your headlight relay...if that works then let me know...i have a new one laying around that i can hook ya up with.
Old Aug 29, 2006 | 08:01 PM
JSpekBB4's Avatar
Default Re: TECH HELP NEEDED: LIGHTS (AnthonyG2003)
would just part of the lights not work if the relay was bad, or does the relay have different sections?
Old Aug 29, 2006 | 08:03 PM
AnthonyG2003
Guest
Posts: n/a
it depends i know when mine went out...i could get my parking lights on but nothing else....except brights.
Old Aug 29, 2006 | 09:08 PM
JSpekBB4's Avatar
alright tried that, still the same thing... heres what I've replaced for the lights so far
combo switch
combo switch harness
all bulbs
Old Aug 30, 2006 | 07:47 AM
JSpekBB4's Avatar
ttt
Old Sep 1, 2006 | 09:13 AM
JSpekBB4's Avatar
ttt, need help everyone
Old Sep 1, 2006 | 01:08 PM
sivikvtec's Avatar
Default Re: (JSpekBB4)
You need to check all of the fuses!! Both under the hood and in the interior fuse box down by the pedals. Especially check the "small light" fuse under the hood. If you're sure all the fuses are good...
remove the dead petal (you'll need a long socket for this)
remove the plastic kick panel on the bottom of the drivers door (its just clips so pull up)
remove the plastic panel that covers the whole fuse box
remove the bolts that hold in the entire fuse box assembly and pull the fuse box towards you.
look on the front and back of the box for melted wires.
That of course is a worse case senario, but check your fuses first
HpTeggy98
Dec 13, 2016 02:14 PM
jnkanta
Feb 23, 2008 04:23 AM
JSpekBB4
Aug 29, 2006 09:56 PM
1JDMDOMINICAN
Oct 28, 2005 06:34 AM
ChargedLude97
13
Feb 12, 2004 01:57 PM
