Braking Question
Old Aug 30, 2006 | 08:13 PM
flipwhip's Avatar
Default Braking Question
Is it normal for your car to pull one way or another if you break really hard? Reason I ask is because if I break really hard my car always wants to pull to the left. I have new inner and outer tie rods and my hub bearings have been replaced so I dont know.
Old Aug 30, 2006 | 08:19 PM
M2B4's Avatar
Default Re: Braking Question (flipwhip)
mine does that and i have a bad alignment so i blame it on that lol dunno if its the reason but its what i blame
flipwhip's Avatar
Default Re: Braking Question (M2B4)
alright ill just blame it on that. (my cars aligned fine though )
Old Aug 30, 2006 | 09:58 PM
petern101's Avatar
could be a torque issue with your radius rods. if they aren't torqued correctly, could cause some discrepancies......
also you could assume that the distance between each caliper and brake master cylinder are different lenghts.........so one might bite down just a tad quicker creating a slight pull
Old Aug 31, 2006 | 04:24 AM
maks's Avatar
I guess where you live it's not much of an issue... but here with rain/snow/ice for a good chunk of the year, not having your breaking balanced, means you spin out and crash.
Just something to consider, I'd get it fixed.
You can start by checking your break pads (micrometer recommended), make sure they are worn evenly on both sides... that can rule out break related issues... after that it's into the suspension setup.
F20Cdriver
Dec 17, 2011 05:22 PM
arinaldi
Jun 21, 2009 08:25 PM
kornerk12
Oct 26, 2008 06:01 PM
SuperSlow
Nov 11, 2005 03:19 PM
mrduke
Apr 30, 2004 09:10 AM
