H23 Vtec
Old Aug 28, 2006 | 06:55 PM
tgh22a's Avatar
Default H23 Vtec
I started a h23vtec build last fall and the machine shop should be done this week. From what I have read you shold only rev the engine to around 7000. If the machine shop balnced the crank rods pistons and flywheel up to 10,000rpms is it just the R/S ration that prevents me from going to 8000? The only reason I'm asking is because I have skunk2 cams and would like to rev higher to see the cams make better power.
I know this doesn't make a diff. but I have new bearings, and would be willing to replace them once or twice a year to be able to rev higher.
Old Aug 28, 2006 | 07:25 PM
2lude4u's Avatar
Default Re: H23 Vtec (tgh22a)
Which block is it, an H23a1 or the JDM H23A?
The JDM version has a redline of 7200 rpm & has larger mains so I'm comfortable reving mine to around 7500 rpm which is where the power is already falling off anyways even with stage 3 cams.
The US version has a redline of ? (6300 rpm thereabouts) with smaller mains. I wouldn't suggest reving it over 7000 rpm's, though I know of guy that his to 8000 rpm regularly. Not very good for longevity because it puts on lot of stress on the cylinder walls because of the lower R/S ratio.
Old Aug 28, 2006 | 08:13 PM
high_revs's Avatar
get it dyno'd, see where the power falls off and no need to rev it higher then that...should be fine....i put 9,000 miles on my h23/vtec and the block had orgionally 227,000 and ended up with 236,000 with no issues revving it to 7200 daily on a bone stock bottom end.....prob didnt make much power past 7000, so dont go crazy wirh revving this this, it will only be harming your motor...
Old Aug 28, 2006 | 10:26 PM
Hawkze_2.3's Avatar
The piston speeds, valve train, and (I would think) lack of oil squirters are also going to keep the redline down.
Old Aug 28, 2006 | 10:31 PM
MadCityLude
Guest
Posts: n/a
Default Re: H23 Vtec (Hawkze_2.3)
Whay not add the oil squirters to the setup? Isn't it a bolt in item?
Old Aug 29, 2006 | 05:26 AM
2lude4u's Avatar
Default Re: H23 Vtec (MadCityLude)
I was surprised to find that the H23A vtec, which has a redline of 7200 RPM, does not originally come with oil squirters. I think an NA street car would be fine without squirters since it won't see the high RPM's often or for long periods. A boosted, or track car could make use of them to cool the OEM pistons.
Old Aug 29, 2006 | 06:13 AM
tgh22a's Avatar
Default Re: (SB tuning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SB tuning &raquo;</TD></TR><TR><TD CLASS="quote">get it dyno'd, see where the power falls off and no need to rev it higher then that...should be fine....i put 9,000 miles on my h23/vtec and the block had orgionally 227,000 and ended up with 236,000 with no issues revving it to 7200 daily on a bone stock bottom end.....prob didnt make much power past 7000, so dont go crazy wirh revving this this, it will only be harming your motor...</TD></TR></TABLE>
That sounds like the best way. I may of been thinking of 6200rpms was the sug. redline. What header did you run?
I have a h22 block with a JDM F22 DOHC crank, crower rods(over kill), new crank and main bearings, and type s pistons. So the set up should be pretty fresh. I plan on putting the oil squirters in, you just have to bend them for clearance. I'm not sure on this but i read that they are not really needed for the setup. Just for a little extra safty.
Old Aug 29, 2006 | 05:58 PM
high_revs's Avatar
i had a custom header built in conneticut it was a 4-1 stepped header.....shitty ground clearance tho....
skam8
Jan 16, 2009 11:50 AM
Dabrybry
Oct 28, 2008 10:33 AM
dk4ever
May 3, 2007 09:18 AM
Power Rev Racing
Sep 9, 2004 04:00 PM
btleier
Oct 5, 2003 05:01 PM
