problem with an intake....
Old Sep 1, 2006 | 06:35 PM
preludejayes's Avatar
Default problem with an intake....
so i bought in intake, now im having problems intalling it....it has a bypass...and im tryin to figure out how to make go under the engine.....but there is no hole to pass the piping though....should i cut?? any one with this problem?
Old Sep 1, 2006 | 06:41 PM
99LudeDude's Avatar
intakes don't go under the engine. They go down through the hole below where your stock airbox used to be. There is a resonator that sits under there and lives inside your front bumper. I believe you have to remove the passenger side wheel well plastic to get to it. Maybe even undo the bumper. Also pics would help.
Old Sep 1, 2006 | 06:43 PM
yea thats what i ment...sorry...i see a whole were the stock intake goes. but the piping wont fit.
Old Sep 1, 2006 | 06:56 PM
98vtec's Avatar
moderator emeritus
Default Re: problem with an intake.... (97preludex1)
with some intakes, mostly the 3" ones, you have to widen the hole to allow the pipe to fit. and you have to cut the pipe to install the bypass valve.
Old Sep 1, 2006 | 08:51 PM
M2B4's Avatar
Default Re: problem with an intake.... (98vtec)
if your intake is a 2 piece then you dont havta cut it. mine came 2 piece with the bypass. and i did havta widen my hole a little take a hack saw to the corners of the hole and hammer the metal down.
Old Sep 1, 2006 | 10:02 PM
Hawkze_2.3's Avatar
Default Re: (97preludex1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97preludex1 &raquo;</TD></TR><TR><TD CLASS="quote"> but the piping wont fit.</TD></TR></TABLE>
If it won't fit, then obviously you might have to do something to make it fit. So lets step back and look at the situation...hole too small for intake....hmmmm...Ah-ha! Make hole bigger and intake will fit!!!!!1234
Old Sep 1, 2006 | 10:38 PM
98vtec's Avatar
moderator emeritus
Default Re: (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">If it won't fit, then obviously you might have to do something to make it fit. So lets step back and look at the situation...hole too small for intake....hmmmm...Ah-ha! Make hole bigger and intake will fit!!!!!1234</TD></TR></TABLE>
lmao
Old Sep 1, 2006 | 11:42 PM
plikit's Avatar
Default Re: (98vtec)
wait wait, i still dont get it.
yeah just widen the hole some. mines a snug fit.
Old Sep 2, 2006 | 05:02 AM
prelude1897's Avatar
+1
Old Sep 2, 2006 | 02:12 PM
well i got the intake in....but i didnt install the bypass.....the hood wouldnt close...so ima going to have to do something about that...
woodenchef
10
Dec 29, 2010 08:25 PM
VeriphastS2K
Honda S2000
29
Mar 31, 2009 03:59 PM
coot_er
Mar 29, 2009 09:26 PM
Acidcrakker
Sep 13, 2007 02:58 PM
BigDawwg6969
15
Jun 8, 2005 03:15 PM
