No tachometer...help
Old Sep 10, 2006 | 10:10 AM
slammed95lude's Avatar
Default No tachometer
So I did my H22 swap and used my h23 distrubuter and coil on the h22, I have no tachometer, runs and idles great but no tach.... any ideas of what to do.
Modified by slammed95lude at 12:55 PM 9/10/2006
Modified by slammed95lude at 1:39 PM 9/10/2006
Old Sep 10, 2006 | 03:49 PM
Default Re: No tachometer (slammed95lude)
Also I am throwing the following codes
- 12 EGR
- 6 ECT....no cooling fan comes on
- 22 V-tec pressure switch
- 1 HO2S
- Oil light was on and flashing as well but that was because the single wire came out to the sensor which I think threw the v-tec pressure switch code
i pulled apart my ecu last nightt and found some dirt andsome oil on the outer cover and inside on the cover.... I cleaned it put it back in and am now running it, it is only flashing code 1. So should I drive it againt o see if a code pulls? Or will it pull at idle
Also I switched out the Temp sensor with a new one and no code yet.
rexthermal
Apr 6, 2008 10:19 PM
mister2racer
10
Jul 1, 2005 08:14 PM
22lude
May 2, 2005 05:59 AM
vtec93accord
Nov 3, 2003 08:09 PM
lsvtec42
Mar 8, 2002 04:01 PM
