headlights dont work
Old Sep 9, 2006 | 02:38 PM
Joe...'s Avatar
Default headlights dont work
so my head lights dont work
but my high beams do.....
and none of the fuses are blown
and the bulb themselves are fine........
anyone got a clue??
Old Sep 9, 2006 | 02:45 PM
M2B4's Avatar
Default Re: headlights dont work (Joe...)
test the wires? maybe its the sockets? or relay. but check the wires for power
Old Sep 9, 2006 | 02:58 PM
prelude1897's Avatar
Default Re: headlights dont work (M2B4)
make sure your harness is still plugged in, and double check your bulbs. Swap them around with your High beams and see if that works..
Old Sep 9, 2006 | 11:42 PM
Joe...'s Avatar
thanks for the help
Old Sep 10, 2006 | 12:02 AM
AznBlueBoy's Avatar
mine had problems....sometimes they would be on but randomly it would turn off
i just took the relay out and slapped it around and put it back in and no problems since......
Old Sep 10, 2006 | 01:08 AM
y0whuddupb's Avatar
Default Re: headlights dont work (AznBlueBoy)
there should be a little white box/clear box next to the low beam bulbs near the fender on each side. about the size of a matchbook. it should be grounded on the chassis. my bolt was loose and it my low beams keep turning off and everytime i'd hit a bump it would touch the chassis and the low beams would light up. so i just tighten them down good and low beams works fine.
pr1madona
Honda CR-V & Element
Oct 1, 2016 11:52 AM
jonny11844
Feb 23, 2014 05:14 PM
dfrear
Classic Hondas
12
Apr 19, 2011 06:57 AM
Loco-B
Nov 19, 2007 07:05 PM
wHiRLdWiDe503
May 15, 2002 12:00 AM
