Front Lip
Old Sep 8, 2006 | 01:39 PM
97BB6Type-SH's Avatar
Default Front Lip
my 97 bb6 came with the OEM accesorie lip. i too it off to clean behind it cuz my bumper was filthy behind the lip. i put the lip back on with the same clips & screws it comes to hold it from the bottom/sides and it doesnt fit flush, has some gaps now. any recommendations to what i can use to make it fit perfect?
Old Sep 8, 2006 | 01:44 PM
bigj505's Avatar
Default Re: Front Lip (97BB6Type-SH)
try to loosin all of the screws and realign to a better fit. then once u get the alignment better, tighten them. otherwise, post pics for better suggestions
Old Sep 8, 2006 | 01:51 PM
Default Re: Front Lip (bigj505)
well my lip only has clips/ screws on the sides. i believe it takes one in the front also but mine doesnt have them. when i bought the car it had a piece of a broken clip in the front under the lip so i took it off. and the whole front of the lip is all loose. i tryed some double stick tape and it worked but then started the gap problem on the side.
Also, where can i get bumper clips because both my front and back bumper sag a little bit and it gets on my nerves because i see the lips sagging inside. i want it to sit flush
Old Sep 8, 2006 | 02:06 PM
ricoMugenlude97's Avatar
Most preludes(BB6's) that I've seen have saggy bumpers. Some worse than others. My clips on the passenger front bumper(first one in front of the wheel) broke off so all i did was drill a couple small holes next to where the oem hole was and zip-tied it to the hole in the fender quick fix until paint time.
Old Sep 8, 2006 | 02:12 PM
Default Re: Front Lip (ricoMugenlude97)
thanks, i guess mines can just wait till paint.
Old Sep 8, 2006 | 05:30 PM
bigj505's Avatar
when i installed my oem lip, i had the clips, but i also had 10mm bolts.... u dont have those bolts?
zoniebutt
Dec 25, 2008 08:22 PM
SilentGiantDC5
Jun 4, 2008 05:49 AM
ejONE.mike
13
Sep 24, 2005 08:13 PM
sittingonROTAS
Sep 17, 2005 07:11 PM
handa
Feb 24, 2005 01:51 PM
