p28 help
Old Nov 14, 2006 | 06:33 AM
Brown-tec's Avatar
Default p28 help
ok so i have a 98 lude and im gonna finally get my tranny swap done. im doing it at this place call Asaa Racing, tehy said that a when swapping it all out, tehy recomend a chipped p28 ecu to replace the old auto ecu, is this the right way to go? and if it is, does it need to be tuned, i know you guys have way more knowledge or experience with suff like this. i jus want my car to be a 5spd. and im only planning to go as far as ~200whp range with teh engine im not planning any forced induction. thnx
Old Nov 14, 2006 | 06:34 AM
Project:PULL's Avatar
Default Re: p28 help (Brown-tec)
Get it tuned. Is ASAA Racing in Houston?
Old Nov 14, 2006 | 06:48 AM
Brown-tec's Avatar
Default Re: p28 help (Project:PULL)
yah, do live in the houston area?
will they tune it for me or do i get it tuned elsewhere?
Old Nov 14, 2006 | 07:42 AM
If they have a dyno and the means to tune a Honda ECU. Never heard of ASAA, but I just started looking for tuners in Houston. I've been pointed towards Jason at St00pid Fast. Haven't contacted them yet though. No website yet but here is their location http://www.stoopid-fast.com/
Where's ASAA?
Old Nov 14, 2006 | 07:44 AM
I'm on NW Side
Old Nov 14, 2006 | 07:46 AM
darkspector2.0's Avatar
If all you want to do is 5spd swap and bolt ons... just get a stock manual ecu... the ECU number slips my mind right now... If you're not planning to do any major mods you don't REALLY need to be able to tune. Not that thte option would be bad, but you'll end up spending more money for just 200hp
IMHO
Old Nov 14, 2006 | 07:49 AM
Default Re: (darkspector2.0)
P13 for H22
Old Nov 14, 2006 | 10:09 AM
Brown-tec's Avatar
9605 Longpoint, Houston, Tx, 77055 (713) 952-2722
Old Nov 14, 2006 | 10:26 AM
98vtec's Avatar
moderator emeritus
tuning is required with a socketed ecu.
Old Nov 14, 2006 | 12:38 PM
MyLilCivic's Avatar
I went from a p13 to a chipped p28 i love it but you will prollt need a Vafc because you bneed to set the vtec diff and the air fuel but after that you will be happy
Old Nov 14, 2006 | 02:19 PM
if you GO with a p28 just get it tuned, getting a chipped p28 and then running a vafc is kinda moot if you ask me
tmrtwo's Avatar
ur gonna need a p13 obd2 manual ecu
Old Nov 14, 2006 | 05:28 PM
98vtec's Avatar
moderator emeritus
Default Re: p28 help (MyLilCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MyLilCivic &raquo;</TD></TR><TR><TD CLASS="quote">I went from a p13 to a chipped p28 i love it but you will prollt need a Vafc because you bneed to set the vtec diff and the air fuel but after that you will be happy</TD></TR></TABLE>
why would you go to a p28 and run a VAFC?
Old Nov 14, 2006 | 07:20 PM
P28 Tuned w/stand alone engine management.
Old Nov 14, 2006 | 07:37 PM
you've been watching too much fast and the furious son...
Old Nov 14, 2006 | 10:08 PM
DIRTYsouthBB6's Avatar
Default Re: (Project:PULL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectULL &raquo;</TD></TR><TR><TD CLASS="quote">P28 Tuned w/stand alone engine management.</TD></TR></TABLE>
Old Nov 15, 2006 | 06:03 AM
Brown-tec's Avatar
Default Re: (DIRTYsouthBB6)
so which way do i need to go? im definetly gettin the p28, do i need to change to obd1 or anytihng like that, b/c i have to pass smog and emissions? im not very good with ecus and stuff, so im pretty confused....thnx
Old Nov 15, 2006 | 10:28 AM
98vtec's Avatar
moderator emeritus
Default Re: (Brown-tec)
read the faq. There is a thread in there that discusses ECU choice. And no, im not goign to link you to it because you need to learn how to use the faq for yourself.
Old Nov 20, 2006 | 07:08 PM
MyLilCivic's Avatar
Try it on the dyno like i did, enough said
Old Nov 21, 2006 | 08:35 AM
iwubmybb4's Avatar
Default Re: (MyLilCivic)
P28s are OBDI, i have a chipped tuned with crome p28 and a vafc. I dont have an oil presssure sensor and had a vafc in hand, so it just sends the signal to the ecu. I ran a chipped p28 for a while untuned, the person that chipped it put a h22 basemap on it. After about 2 months i finally got it tuned, i had a way smoother power band and loved it that much more. So get it tuned if you have the money for it right now, but if you dont, have them chip it with an h22 basemap.
Old Nov 21, 2006 | 09:12 AM
98vtec's Avatar
moderator emeritus
Default Re: (iwubmybb4)
why do you have a vafc as well?
Old Nov 21, 2006 | 05:21 PM
iwubmybb4's Avatar
Default Re: (B.Rabbit)
because i dont have an oil pressure sensor, and i didn't want to spend 90 on one at honda.
Old Nov 22, 2006 | 12:55 AM
tegman85's Avatar
arent vafc's like 200??
Old Nov 22, 2006 | 09:15 AM
iwubmybb4's Avatar
Default Re: (tegman85)
yeah, but i had one laying around in my room.
Old Nov 22, 2006 | 11:26 AM
JDMhondalude22's Avatar
is it a def. notice in performance going from a p13 to chipped p28? if i had a vafc would i still have to go get it tuned?
