H22 Idle Problem
Old Nov 19, 2006 | 03:29 PM
dek1mfk's Avatar
Default H22 Idle Problem
Well i fixed all the vaccum hoses and clean my IACV and FITV...and I have my distributor turned forward all the way, the car runs fine when in gear, but at idle or neutral, the RPM stays at 2K steadily....should i retard the distributor timing to solve this issue?
Old Nov 19, 2006 | 03:47 PM
redtop22's Avatar
Default Re: H22 Idle Problem (dek1mfk)
Have you tried adjusting the idle screw on the side of the TB?
Old Nov 20, 2006 | 04:20 AM
black06lude's Avatar
trie a different plug to the map sensor there should be two on the same side of the motor
Old Nov 20, 2006 | 06:13 AM
NoVALude's Avatar
Of course I saw this after I posted.....am in the same boat man. 92 Lude with a 99 H22 and same issue. adjuted throttle screw as well for mine, and no luck. Have you tried yet with any success?
Old Nov 20, 2006 | 06:20 AM
JasonST's Avatar
Default Re: H22 Idle Problem (NoVALude)
Why is ur timing advanced so much? Try setting it to stock.
Old Nov 20, 2006 | 02:56 PM
dek1mfk's Avatar
Default Re: H22 Idle Problem (JasonST)
OK guys, i set the timing back a little bit and closed the idle screw one more turn....my idle is now at 1200-1300...i will try to adjust the IACV screw since i cleaned the IACV, to see if that is the problem...but so far, idle is 1200-1300 at idle, but once driving, it is fine
blkspd5
22
Jan 27, 2020 11:55 AM
cfoland
Feb 19, 2011 08:33 PM
only1tmac32
Oct 19, 2008 08:26 PM
jdmjonnyacc
Apr 26, 2006 10:13 PM
Kp_VtekNiks
Sep 1, 2003 01:54 AM
