NEED HELP- Valve cover Bolts snapped!
I recently took my Valve Cover off to paint it, removal went fine. When I put the Valve Cover back on I began to tighten the nuts down to 9ft lbs. They never made it, they either snapped or the whole bolt would just rotate with the nut. What do I do? I mean Im not sure what to do since its an aluminum head. Pls help.
Re: NEED HELP- Valve cover Bolts snapped! (lude98SH)
Ok....but I mean if its sripped out of the head what can I do. I thought once aluminum was stripped it was stripped.
Re: NEED HELP- Valve cover Bolts snapped! (flipwhip)
Remove the valve cover and buy new studs to replace the ones you snapped.
I never torque these bolts because they will snap. Use a 1/4" ratched and snug them.
Re: NEED HELP- Valve cover Bolts snapped! (PrecisionH23a)
Yes thats true .....if you were going to torque specs I doubt you would strip the threads on the head.
Those things snap easier than tooth picks, just buy a replacement and your done. I always tighten then till you can feel they are harder to turn.
They are under $5 dollars, its been a while since i purchased some. Buy em at Slhondaparts.com or Hondaautomotiveparts.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flipwhip »</TD></TR><TR><TD CLASS="quote">any idea on prices? Thanks alot guys.</TD></TR></TABLE>
Not sure. I might have one from a spare Civic engine if they are too expensive from the dealer.
Just tape a pic of the one on your car and send it to me. I will compare it to the one I have.
well the thing is Im pretty sure just about all of the bolts are spinning, but thats for all the info and the link.
lol kinda off the subject but one day i was workin on my cams and i lost the lil seal/ washer or figure 12 on the diagram....... know where i can replace those?
Re: NEED HELP- Valve cover Bolts snapped! (JDM custums)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a »</TD></TR><TR><TD CLASS="quote">
I highly doubt you stripped where it connects to the cam cap/head.</TD></TR></TABLE>
is this picture from the helms manual???
Re: NEED HELP- Valve cover Bolts snapped! (97 Sleeper)
No, exploded parts diagram from http://www.slhondaparts.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a »</TD></TR><TR><TD CLASS="quote">No, exploded parts diagram from http://www.slhondaparts.com</TD></TR></TABLE>
thanks a lot thats a very helpful site
http://www.hondapartsdeals.com ftw
there is no need to go more than snug with these though....there is very little force on the valve cover....
Re: (flipwhip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flipwhip »</TD></TR><TR><TD CLASS="quote">When I screw them into the head do I have to tighten it to a certain Ft. LBS?</TD></TR></TABLE>
I would just tighten them until they're snug, then maybe an extra 1/4 turn. There is no pressure on the VC, you're just tightening them to seal the VC gasket.
thx for that site lol VERY useful... lol but I found a cheaper and faster way to get the seals ^_^ pick a part at the junk yard ^_^ lol put w/e it is u need IN your pockets lol ^_^
