snapped 2 wheel studs
Old Nov 19, 2006 | 04:16 PM
snzh22's Avatar
Default snapped 2 wheel studs
i snapped 2 on the front passenger side wheel, opposite of each other, so its not as bad as having 2 studs that are next to each other. i kno that i obviously shouldnt take turns to fast...
so my question is: 1) what is the max speed i should be goin on the hwy? 65? i have no choice, i have to drive home...and 2) about how much do shops charge to have studs replaced?
Old Nov 19, 2006 | 04:26 PM
ralpheezy's Avatar
Default Re: snapped 2 wheel studs (95hprelude)
i got charged 140 just to replace one.
might as well do it yourself, if you can.
Old Nov 19, 2006 | 04:34 PM
snzh22's Avatar
Default Re: snapped 2 wheel studs (ralpheezy)
what shop did u go to, a big name shop or a local? i remember pepboys telling me it would be either 30 or 80, depending on the type of rotors i have or something.
Old Nov 19, 2006 | 04:47 PM
BergRacing21's Avatar
there easy to fix yourself...cause i've heard of plenty of people gettin ripped from shops...when they take maybe 20-30 minutes to replace.
Old Nov 19, 2006 | 05:02 PM
snzh22's Avatar
Default Re: snapped 2 wheel studs (BergRacing21)
anyone have a write up?
Old Nov 19, 2006 | 05:04 PM
snzh22's Avatar
any response to the speed i should keep it under?
Old Nov 19, 2006 | 06:17 PM
manbearpig's Avatar
it's not that easy.......you have to have a press to get the stud out, I broke one and I've been riding on it for like 6 months.....Take it to a moore and patron or midas or something...........they should be able to do it for <$50 (hopefully)
Old Nov 19, 2006 | 06:20 PM
Hawkze_2.3's Avatar
/\/\You don't have to have a press, a hammer will do fine.
You'll have to of course take off the wheel and it helps to take off the rotor and caliper. I think a stock stud will come out without removing the hub or grinding, but to install ARP extended studs you have to either pull the hub off or grind off a section big enough for the stud to fit through to get it in.
Just hammer out the stud and use an open ended lug nut and washer to pull it back through.
Old Nov 19, 2006 | 06:56 PM
soundbomber's Avatar
Default Re: snapped 2 wheel studs (Hawkze_2.3)
if you must do it yourself, slide hammer is the way to go.
Old Nov 20, 2006 | 07:46 AM
prelude_h22vtec's Avatar
the ones in the back are easy...the ones in the front take twice as long. while you're in there, you might as well replace the other two also. i've broken like 5 studs in the 2 years i've had my car. 3 in the front and 2 in the back. on all four corners. a slide hammer will definetely do the trick on the front hubs.
Old Nov 20, 2006 | 11:38 AM
manbearpig's Avatar
The stock stud will not come out (on the front) without grinding or removing the hub. My stock stud, broken off at the rotor will not come out without grinding........let alone a new full sized one (even with removing caliper and all). I'll take pics if you need me to.
Old Nov 20, 2006 | 12:09 PM
snzh22's Avatar
Default Re: snapped 2 wheel studs (joinerneal)
midas told me it wil cost 55 for the 2 on the fronts. i think its worth it for not having to go thru the trouble.
pepboys said 100 and firestone says 85...so yea i think ill go with midas ha
Old Nov 20, 2006 | 12:10 PM
the best bet is to pull off the arm yourself, that saves a lot in labor. or just buy my 5 lug swap. you can have 20 new arp extended studs
Old Nov 20, 2006 | 01:02 PM
rich045's Avatar
* B A N N E D *
Default Re: snapped 2 wheel studs (soundbomber)
55 is decent, i got charged 60 bucks for 1 when i had my 240... but that was at some rednecks shop...
Old Nov 20, 2006 | 01:04 PM
JDM custums's Avatar
lol guys its not that hard to replace the studs. just buy new studs and ask the clerk how to put them on... i broke 3 of them usin a air gun to take them off... all i had to do was take off a bolt/screw and put new ones in...
Old Nov 20, 2006 | 01:06 PM
and yes it took me about 30-40 minites per stud... all i used was a hammer a wrench and some muscle....
Old Nov 20, 2006 | 02:44 PM
typeS's Avatar
Default Re: (JDM custums)
it is easy if you have a grinder to cut the old one, and remove a bit of the backing on the new one.
Old Nov 20, 2006 | 07:03 PM
ralpheezy's Avatar
pep boys charged me $140. i was younger then and i had no idea. later on, when i was getting new tires, discount tire snapped the one that pep boys put on and they gave me a free replacement at midas.
Old Nov 20, 2006 | 08:54 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joinerneal &raquo;</TD></TR><TR><TD CLASS="quote">The stock stud will not come out (on the front) without grinding or removing the hub. </TD></TR></TABLE>
Now that I think back on it I clearly remember not having to grind anything until I put the ARPs in. So if it will not come outwithout grinding, how did I do it? Am I just that good?
Old Nov 20, 2006 | 09:12 PM
nah... we all do things once and call back on it and think "wtf how did I do that" you know
Old Nov 21, 2006 | 08:25 AM
manbearpig's Avatar
Not to be an ***..... But I guess you are that good.......that, and our cars must be different. *on mine* it is impossible to remove it by "pushing" or beating....or whatever you want to do.... It is going to hit the area behind the stud..... end of story.
Old Nov 21, 2006 | 08:40 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joinerneal &raquo;</TD></TR><TR><TD CLASS="quote">Not to be an ***..... But I guess you are that good.......that, and our cars must be different. *on mine* it is impossible to remove it by "pushing" or beating....or whatever you want to do.... It is going to hit the area behind the stud..... end of story. </TD></TR></TABLE>
If you rotate the hub, there are some spots that give more clearance than others. I do know that I f'ed up the threads pretty bad getting them out....but they came out. Hopefully the OP can get his out.
Old Nov 21, 2006 | 04:10 PM
hawkze, post that pic of how you grinded the knuckle
Old Nov 21, 2006 | 09:05 PM
Hawkze_2.3's Avatar
Default Re: (prelude_h22vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude_h22vtec &raquo;</TD></TR><TR><TD CLASS="quote">hawkze, post that pic of how you grinded the knuckle</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1395105&page=2
Old Nov 21, 2006 | 10:44 PM
lol wow...
