Ignition Column problem
Old Nov 20, 2006 | 01:21 PM
saikou's Avatar
Default Ignition Column problem
Parked the car and took the key out and the chime noise for when you leave the key in the ignition and open the door was going off. Now I cannot lock my doors before I step out of the car with the lock switch.
How would I go about fixing this? The key still stays in the ignition column when I fire her up. Its just that when I take the key out, it thinks it is still in there when I open the door.
Old Feb 21, 2007 | 04:30 PM
mhgleitz's Avatar
Default Re: Ignition Column problem (saikou)
Mine used to do the same thing. Bang very hard on the underside of the steering column until you hear a metal click. The bottom part of your palm works very nicely. Once you get the technique down, one good hit should do it.
jakop92
Apr 23, 2010 11:35 AM
honda314
Aug 19, 2009 10:25 PM
pos94accord
Aug 7, 2009 11:13 AM
oes
Dec 9, 2003 06:38 AM
ophdehEEzY
Jun 17, 2003 03:30 AM
