Battery Relocation Summit
Old Nov 18, 2006 | 07:26 AM
kornerk12's Avatar
Default Battery Relocation Summit
I have the summit battery relocation kit, how do use run the power wire to the starter and fuse box because it doesnt come with a distribution box ?
Old Nov 18, 2006 | 07:29 AM
mgags7's Avatar
i think they want you to run the wire straight to the starter, then run a little one from there to the fusebox
or you can do like i did, and get an ebay distribution block....those kits are crap, i made my own..
Old Nov 18, 2006 | 07:49 AM
Hawkze_2.3's Avatar
Default Re: Battery Relocation Summit (kornerk12)
Also, you can just bolt 2 wires together as long as you have good insulation around the exposed metal.
Old Nov 18, 2006 | 02:33 PM
esedulerp5tenin's Avatar
Default Re: Battery Relocation Summit (Hawkze_2.3)
i simply kept the starter and fusebox wires bolted together, than ran a 4 gauge from the trunk, put a ring terminal on the end, then sandwhiched that between the other to on the bolt.
easy
Old Nov 18, 2006 | 02:42 PM
fastludeh22's Avatar
Default Re: Battery Relocation Summit (esedulerp5tenin)
ya i keep my wiring stock, ran 2 gage from the trunk to where the stock postive term hooked up too
Old Nov 18, 2006 | 03:13 PM
Prudz_lude's Avatar
Default Re: Battery Relocation Summit (fastludeh22)
PLEASE MAKE A WRITE UPP!!!!!
Old Nov 18, 2006 | 04:50 PM
Apex1972's Avatar
Default Re: Battery Relocation Summit (Prudz_lude)
I ran 4 gauge directly from the alternator to the positive side of the battery. I also had a 100 amp circuit breaker in between the alternator and the battery located under the hood near the fuse box. There was also a 4 gauge coming back from the battery to the fuse box under the hood.It was also run through a separate 100 amp breaker. The reason I used 2 cables is because the distance from the trunk to the fuse box may be too long for 6 or 8 gauge, and you want to be sure you have a strong charge coming from the alternator as well as going back to all the cars electrical circuits from the battery. Connect the starter wire to one side of your fuse or circuit breaker and the other side if the fuse or breaker to the 4 gauge going to the batt. Ground the battery to one of the 10mm bolts that are located under you back seat. Make SURE YOU USE FUSES OR CIRCUIT BREAKERS FOR THIS!!!! Sorry I do not have pictures of this but it was done to a car I no longer have.
Old Nov 18, 2006 | 06:31 PM
mgags7's Avatar
https://honda-tech.com/zerothread?id=1462936
my writeup ftw
Old Nov 19, 2006 | 01:40 PM
Prudz_lude's Avatar
Default Re: (bb4ever)
looks like a great write up but the pictures are not working
notnic3
Jun 12, 2017 11:26 AM
Wingate457
Mar 10, 2011 03:49 AM
bernymachd3
Dec 3, 2009 05:45 PM
b16crx0062004
17
Sep 30, 2004 10:45 AM
ClubSiRacer
Jan 30, 2004 04:18 PM
