Bad Timing Light?
Old Dec 1, 2006 | 10:33 PM
deucedeuceEK's Avatar
Default Bad Timing Light?
I checked my timing for the first time since my h22 swap. The dizzy was already all the way advanced before I even started the motor. I retarded it just a little and drove it a few weeks before I could borrow a light from a friend. Car ran great with no problems. Well I checked the timing, and I could not see any marks on the flywheel unless the dizzy was all the way retarded. And then I could just barely see a white mark. Anyways, I left the dizzy retarded all the way bacause the timing is still advanced. But now my car is boggy as hell. Also my car missfires every now and then. Before I change my timing belt to fix the problem since I believe my problem is with the belt advanced a tooth, should I try another timing light?
Incase I make no since above. Im merely asking if timing lights can go bad and give un-acurate readings. Thanks
Old Dec 1, 2006 | 10:49 PM
mgags7's Avatar
Anything can go bad
I wouldn't ghetto rig your spark timing to make up for your cam timing being off....Don't drive that car until you make sure that the belt is on right
95EG2
Jun 3, 2011 07:11 PM
slow-ef
Mar 26, 2009 10:53 AM
rhdins
Aug 25, 2008 07:26 PM
xJDMCx
Sep 15, 2006 09:34 AM
DieMaster
Jul 2, 2004 09:09 AM
